Engineering Solutions
The Engineering Solutions User Interface
The main areas of the Engineering Solutions application window which have standard referencing names are defined in the picture and described in the table below.
GUI_schematic_110_engsol
Title Bar
Located at the top of the Engineering Solutions window, this displays the current Engineering Solutions version. It also displays the path and name of the file currently open in the active session.
Menu Bar
Located just under the title bar. Like the menu bar in many graphical user interface applications, these menus "drop down" a list of options when clicked. Use the menu bar to access Engineering Solutions panels and functionality in a process based manner working left to right across the menu bar.
Toolbars
Toolbars contain groups of icons used to perform the most common tasks. Each toolbar can be docked to any of the indicated toolbar locations. Toolbars can also be undocked or free-floating in the application window.
Graphics area
Located in the center of the Engineering Solutions application window, this area is where the model displays.
Tab area
Located on the left, right, or both sides of the graphics area, the tabbed areas display the Utility menu, all browsers and tabbed dialogs.
Tab areas can be toggled on or off by use of the View menu.
Individual browsers can be shown or hidden from the tab area by selecting the specific browser from the View menu.
You can click-and-drag on the tab of the browsers and tabbed dialogs to move them between the left and right tab area.
Quick Access Tool
Quickly find and access tools, panels, and browsers, and create solver cards.
Panels area
The panel area includes the panels and the command window. The panel area is configurable from the View menu and can be positioned on the top or the bottom of the graphics area.
Command window
You can type Tcl/Tk commands directly into this command prompt window and execute them instead of using the graphical user Interface. The command window can be turned on and off in the View menu.
Status bar
Located at the bottom of the Engineering Solutions application window, the status bar displays various model status information.
Current Include/ Component/ Load Collector
The current include, component and load collector displays in these areas of the status bar. Click the area to open a panel that allows you to change the current include, component or load collector.
See Also:
Display Controls
Input Controls
Working with Files
