Toolbars contain groups of icons used to perform the most common tasks. Each toolbar can be docked to any of the toolbar locations. Toolbars can also be undocked or free-floating in the Engineering Solutions application window.
Toolbars can be turned on or off from the View menu. Check marks indicate the status of each toolbar, checked for on and unchecked for off. Clicking an item in the toolbar's sub-menu toggles the state between "on" and "off". |
Toolbars can be moved and "docked" to any of several possible locations inside the Engineering Solutions environment. Each toolbar has a toolbar handle; this is used to drag a toolbar on (docked) or off (undocked) a toolbar area. The available toolbar areas in the Engineering Solutions frameworks are shown in the Engineering Solutions User Interface topic. Within each of these areas a toolbar can be docked or undocked. Move and re-dock a toolbar
The mouse pointer changes to a
In order for a toolbar to be docked, it must be "dropped" over a valid toolbar area. To dock a toolbar on a toolbar area that is currently collapsed (that is there are no toolbars currently shown in that area) simply release the mouse button where the toolbar area would be if it were expanded.
See Also:
