Engineering Solutions
Standard Toolbar
Standard Toolbar
Standard Toolbar
The Standard toolbar controls basic operations, including starting a new session, opening and saving .hm binary files, importing and exporting solver decks and geometry files, setting the current user profile and results files, and working with command and tcl files and utilities.
standard_toolbar
The Standard toolbar can be turned on and off by clicking View > Toolbars > Standard.
The detailed behavior of each toolbar icon is described in the table below. Note that some icons have different behavior depending on whether they are clicked with the left mouse button or the right mouse button.
Icon
Left-click
LEFT Behavior
Right-click
RIGHT Behavior
fileNewModel-24
New .hm file
Close the current .hm file and open a new blank .hm file.
Same
fileOpenModel-24
Open .hm file
Open standard Open dialog; browse for .hm file to open.
Same
fileSaveModel-24
Save .hm file
Save current .hm file.
Same
fileImportSolver-24
fileImportModel-24
fileImportGeometry-24
fileImportConnectors-24
Import Solver Deck
Import Model
Import Geometry
Import Connectors
Open Import tab; Enter information to import connectors, FE models, geometry, or HM models.
Select option from Menu
Or
Left-click lower right arrow
Right-click to expand options; Left-click an icon to set new current icon and perform the icon’s left-click behavior.
fileExportSolver-24
fileExportModel-24
fileExportGeometry-24
fileExportConnectors-24
Export Solver Deck
Export Model
Export Geometry
Export Connectors
Open Export tab; Enter information to export connectors, FE models, geometry, or H3D files.
Or
userProfile-24
Load User Profile
Open User Profile dialog; Select user profile to load.
Same
fileOpenResults-24
fileOpenTemplate-24
Load Results File
Load Solver Template
Open Load Results dialog; browse for results file to load.
Open Load Solver dialog; browse for files to load.
Or
See Also:
Toolbars
