Engineering Solutions
Checks Toolbar
Checks Toolbar
Checks Toolbar
The Checks toolbar contains quick access to functionality for various checks and calculations that are commonly used in the model building process.
checks_toolbar_sa
The Checks toolbar can be turned on and off by clicking View > Toolbars > Checks. The detailed behavior of each icon is described in the table below:
Icon
Left-click
LEFT Behavior
Right-click
RIGHT Behavior
distanceBetweenNodes-24
Distance panel
Opens the Distance panel.
Same
length-24
Length panel
Opens the Length panel.
Same
massManager-24
Mass/Area Calc panel
Opens the Mass Calc panel.
Same
edges-24
Edges panel
Opens the Edges panel.
Same
features-24
Features panel
Opens the Features panel.
Same
faces-24
Faces panel
Opens the Faces panel.
Same
normals-24
Normals panel
Opens the Normals panel.
Same
penetration-24
Penetration/Intersection Check
Opens the Penetration panel.
Same
checkElems-24
Check Elements panel
Opens the Check Elements panel.
Same
infoSummary-24
Model Summary panel
Opens the Summary panel.
Same
infoSummaryLoads-24
Loads Summation panel
Opens the Loads Summary tab.
Same
infoCount-24
Count panel
Opens the Count panel.
Same
See Also:
Toolbars
