Engineering Solutions
Image Capture Toolbar
The Image Capture toolbar contains functionality for capturing .bmp, .jpg, and .eps images of the graphics area, panel area and any user defined rectangular area or frame. The Image Capture toolbar is only supported and visible on the Windows platforms.
image_capture_toolbar_sa
The Image Capture toolbar can be turned on and off by clicking View > Toolbars > Image Capture. The detailed behavior of each icon is described in the table below:
Icon
Left-click
LEFT Behavior
Right-click
RIGHT Behavior
imageFileSave-24
Save Image to File/Clipboard
Toggle on/off saving.bmp image capture icons to file or to clipboard.
Same
imageGraphicsArea-24
Capture Graphics Area
Capture.bmp image of graphics area. If Save Image to File toggle is on, then additionally enter a file name in the Save As dialog, otherwise use standard <ctrl>-v functionality to paste the image from the clipboard into the desired application.
Same
imagePanelArea-24
Capture Panel Area
Capture .bmp image of panel area. If Save Image to File toggle is on, then additionally enter a file name in the Save As dialog, otherwise use standard <ctrl>-v functionality to paste the image from the clipboard into the desired application.
Same
imageBoxArea-24
Capture Rectangular Area
Left-click and hold to draw a rectangle around any portion of the Engineering Solutions window; release to capture .bmp image of rectangular area. If Save Image to File toggle is on, then additionally enter a file name in the Save As dialog, otherwise use standard ctrl-v functionality to paste the image from the clipboard into the desired application.
Same
imageFrameArea-24
Capture Frame
Left-click and hold to select any frame in the Engineering Solutions window, as you move the mouse over a valid frame the frame will highlight; release to capture .bmp image of selected frame. If Save Image to File toggle is on, then additionally enter a file name in the Save As dialog, otherwise use standard ctrl-v functionality to paste the image from the clipboard into the desired application.
Same
imageJPGCapture-24
Capture .jpg image of graphics area; enter a file name in the Save As dialog; click Save. .jpg options can be set from the Options > Postscript panel. The Options panel can be accessed from the Preferences menu, Graphics sub-menu.
See Also:
Toolbars
