To turn the Scripting toolbar on and off, click View > Toolbars > Scripting.
The detailed behavior of each icon is described in the table below:
Icon |
Function |
Behavior |
Create Tcl/Tk script |
Start a new HyperMath session. |
Open Script/ Command file |
Open a Tcl/Tk script in HyperMath, or open a command file in a text editor. |
Debug Tcl/Tk script |
Prompts you to debug a selected script. |
Run Tcl/Tk script/ Command file |
Opens Run Tcl/Tk script dialog, prompting you to select script to open. Run an existing command file. |
New HyperMath Script |
Start a new HyperMath session with a blank HyperMath script file. |
Open HyperMath Script |
Select a HyperMath script to open and edit. |
Debug HyperMath Script |
Select a HyperMath script and load HyperMath in debugging mode. |
See Also:
