Engineering Solutions
Display Toolbar
Display Toolbar
Display Toolbar
The Display toolbar controls what entities display in the graphics area, primarily by masking entities to hide or display. To turn the Display toolbar on and off, click View > Toolbars > Display.
display_toolbar_sa
The table below describes the behavior of each tool button on the Display toolbar.
Icon
Left-click
LEFT Behavior
Right-click
RIGHT Behavior
selectElemsByBoxMask-24
Mask
Opens the Mask panel.
Same
selectElemsByReverseMask-24
Reverse Elements
Reverses the mask state of all elements in currently displayed collectors.
Reverse All
Reverses the mask state of all entities (elements, loads, and so on) in currently displayed collectors.
selectElemsByAdjacentMask-24
Unmask Adjacent
Unmasks the row of elements adjacent to the currently displayed ones. If some of the unmasked elements reside in components that are currently not displayed, those components will also be unmasked.
Same
selectElemsUnmaskAll-24
Unmask All
Unmasks all entities (elements, loads, and so on) in the currently displayed collectors.
Same
selectElemsByBoxUnmask-24
Mask Not Shown
Masks all entities (elements, loads, and so on,) located outside of the graphics area but in currently displayed collectors.
Unmask Shown
Unmasks all entities (elements, loads, and so on) located outside of the graphics area but in currently displayed collectors.
displaySphericalClipping-24
Spherical Clipping
Opens the Spherical Clipping panel, from which you can select a center point and radius for the spherical clipping and enable or disable it.
Same
search-24
Find
Opens the Find panel.
Same
infoNumbers-24
Display Numbers
Opens the Numbers panel.
Same
scale-24
Display Scale
Displays a scale in the lower, right-hand corner of the graphics area. Use this tool to measure different parts of your model. The numbers on the scale are dependent upon the dimension of the model and the zoom factor you are currently using in the graphics area.
Same
displayElemHandles-24
Display Element Handles
Toggles element handles on/off. The same operation can be performed from the Graphics subpanel located in the Preferences > Graphics menu.
Same
displayLoadOptions-24
Display Load Handles
Toggles load handles on/off. The same operation can be performed from the Graphics subpanel located in the Preferences > Graphics menu.
Same
visualizationLoadsHeadTail-24
Change Load Vector (Tip/Tail) at Application Point
Points the load vector toward the load application point (tip), or away from the load application point (tail) when the tip or the tail of the load vector is attached to the load application point.
Note:The direction of the vector does not change when you select this option.
The same operation can be performed in the Visualization tab when Loads is selected.
Same
displayFixedPoints-24
Display Fixed Points
Toggles fixed points on/off. The same operation can be performed from the Graphics subpanel located in the Preferences > Graphics menu.
Same
See Also:
Toolbars
