Engineering Solutions
Card Filter
Card Filter
Card Filter
Note:This feature of the Entity Selector appears only when the user profile is set to a solver type; it does not display in the default HyperMesh user profile.
The Card Filter control allows you to restrict the list of entities displayed when you click the Entity Selector.
card_filter_1
Some panels present a list of entities when you click their Entity Selector button, instead of the Advanced Menu Selection options. In
this example, the Card Filter control is circled in red.
It does this by limiting the list to only those entities that have the specified card type associated with them. Not all entities display in this fashion, so the Card Filter feature is limited to the following entity types:
Assembly
Beamsection collector
Blocks
Component
Contact surfaces
Control volume
Curves
Ddvals
Groups
Laminates
Load collector
Load steps
Material
Multibodies
Plies
Plots
Property
Sensors
Sets
Shapes
System collector
Tags
Titles
Vector collector
To filter the entity list, click the switch for the filter and select card.
card_filter_2
This displays a read-only text field adjacent to the Card Filter control. Click card to open a pop-up window that lists all of the cards defined in your model for the selected type of entity, and pick the card that you wish to filter by.
Once selected, only entities with the chosen card type will display in the entity list on the panel.
To remove the filter, simply use the switch to select all (displaying all entities regardless of card association) or no card (displaying only those entities that do not have a card at all).
