AcuSolve is a leading general-purpose finite element based Computational Fluid Dynamics (CFD) flow solver with superior robustness, speed and accuracy. AcuSolve can be used by designers and research engineers with all levels of expertise, either as a standalone product or seamlessly integrated into a powerful design and analysis application. Quality solutions can be obtained quickly without iterating on solution procedures or worrying about mesh quality or topology. The fluid structure interaction (FSI) capabilities available in AcuSolve enable you to perform multi-physics analysis of complex scenarios in an efficient manner.
The interfaces in HyperMesh and HyperView ensure a smooth integration of AcuSolve into the HyperWorks framework.
