Engineering Solutions
Connector Location
Connector Location
Connector Location
This is the position in space at which a connector entity is created.  The valid entities that can be used to define the connector location depend on the connector type, as shown below:
Spots
nodes
The connector icon is created at the node location.
points
The connector icon is created at the point location.
lines
The connector icon is created at the center of the selected line.  Only one connector is created for each line, but the line may be split into multiple projection locations as specified by the offset, spacing, and density values.
nodelist
The nodelist can be considered as to be a line. The treatment is absolutely the same.
Bolts
nodes
points
lines
This connector is only used for repetitive holes in a certain, constant distance along the selected line.
Seams
lines, linelist
nodelist
Areas
elems
The connector icon is created at the elements location.  Only one connector is created for each group of elements, but the area may be subdivided into multiple projection locations as specified by the nodes of the selected elements.
The area can be remeshed to get different projection locations.
surfs
The connector icon is created at the surface location.  Only one connector is created for each surface, but the area may be subdivided into multiple projection locations as specified by the mesh type and element size values.
linelists / lines
One connector icon is created for each line.  The line is extruded to an area considering the width and the offset values.  The area may be subdivided into multiple projection locations as specified by the mesh type and element size values.
If line combine is activated, adjacent lines are treated as one line and produce one area connector.
nodepath
The nodelist can be considered as to be a linelist. The treatment is absolutely the same.
Masses
nodes
points
See Also:
Connector Terminology
