Engineering Solutions
Connector State
Connector State
Connector State
The connector state is defined as one of the following types:
unrealized
The initial definition of the connector entity after it is created.  The connector is displayed in yellow.
realized
The connector is considered realized only if weld creation at the connector was successful.  The connector is displayed in green.
modified
The connector is considered modified when one or more of its corresponding attributes have been edited in the Connector Entity Editor. The connector is displayed blue.
failed
The connector is considered failed if the weld creation at the connector was not successful.  The connector is displayed in red.
Note:The color code provides an easier way to visualize and filter connectors based on their state.
A connector that was realized can revert back to being unrealized if, for example, a link entity is suppressed from its definition, or the weld element is deleted.
See Also:
Connector Terminology
