Engineering Solutions
Connector Entity Browser Global Display Tools
Use this tool set to control the display of connectors.
connector_tree_global_display_tb
The functionality works at three levels; if nothing is selected, this is called the global level, the display action will work on all connectors. At the folder level, if the folder is highlighted then the action will only operate on the connectors within the folder. At the local entity level, if a single or multiple connectors are selected then the operation will operate only on those selected.
checkboxSelectAll-24
Display All
checkboxUnselectAll-24
Display None
checkboxSelectReverse-24
Display Reverse
Note:These buttons only affect the display state. They do not actually remove entities from the model, but only show or hide them in the graphics area.
