Engineering Solutions
Connectors User Control Mode
Each individual connector can be placed in a user control mode using either the *CE_SetSpecificDetailById or *CE_SetSpecificDetail commands.  This user control mode is most useful for automated Tcl scripts.  Once in user control mode, the following procedures are possible for a given connector:
Pre-existing FE can be registered as a given connector’s realization by using the *CE_FE_Register command.
Connectors can be edited without automatically unrealizing (as happens most notably when a link is added or removed from a connector, or when an FE realization entity is deleted).
A connector’s state can be manually changed from realized to failed, or from failed to realized by using either the *CE_SetSpecificDetailById or *CE_SetSpecificDetail commands.  A connector’s state will not change to or from the unrealized state using this method.
Once a connector is placed into you control mode, you control mode remains active until an unrealize command is called (such as *CE_Unrealize), an already realized connector is re-realized, or you control mode is manually turned off with either the *CE_SetSpecificDetailById or *CE_SetSpecificDetail commands.  While a given connector is in user control mode, it may not behave the same as a normal connector.  Specifically, there are a number of scenarios where a user-controlled connector will not auto unrealize in response to database changes that would cause a normal connector to auto unrealize.
Note:It is strongly recommended that when FE is registered to a user-controlled connector, that the connector links and other necessary details should also be set with a given connector (so that the connector can properly re-realize if a user interactively requests it to).  At the bare minimum, connectors should know which links they are to connect.
See Also:
*CE_FE_Register
