Engineering Solutions
Convert Style
Convert Style
Convert Style
Use the Convert option to convert connectors of one specific style into a different style, for example a spot connector into a bolt connector.
To use this option, highlight the connector(s) you want to convert, then right-click and select Convert > Style (spot, bolt, seamline) from the context menu.
connectors_convert
The converted connector(s) will be unrealized and placed in the Undefined folder. Once you convert a connector, you will not be able to revert it back to its original state. The only information that will be retained includes: number of layers, tolerance, and link information.
In the Convert Settings you can specify whether line connectors should remain as line connectors after the conversion or if they should be converted to single point connectors per each connector point. This option is only applicable when spot or boltlines are being converted to seamlines.
dialog_convert_settings
