Engineering Solutions
Editing Surfaces
Editing Surfaces
Editing Surfaces
Each surface contains one or more faces. It is usually preferable to combine multiple faces into one surface entity before you use the meshing tools. This allows them to be meshed at the same time.
You can use the Surface Edit panel to modify surface geometry when it is necessary to make changes before you generate a mesh.
For example, to trim a surface with a line, use the trim with lines subpanel of the Surface Edit panel. You must select the surface and the line and specify a direction vector. The surface is trimmed by sweeping the line along the vector and intersecting the surface with the sweep.  If the sweep does not intersect the surface, the surface is not trimmed.
editing_surfaces_01
editing_surfaces_02
A circle and a surface (represented
with surface lines) before trimming.
After the circle is used to trim the surface,
two new surfaces are created (shown
highlighted) and the original surface is trimmed.
To trim one surface with another, use the trim with surfs/planes subpanel.
editing_surfaces_03
editing_surfaces_04
Two surfaces before trimming.
The smaller surface is split into two surfaces
after it is trimmed with the larger surface.
See Also:
Surface Edit panel
cleanup subpanel
General Process for Building Models
