Engineering Solutions
Model Setup
Model Setup
Model Setup
This section describes how to build a finite element model.  In general, the following building process is used:
Create collectors
Obtain line and surface geometry from an external file, or hand digitize the data
Reconcile conflicts in the geometry and prepare it for use
Build the model by using element-building panels
Verify the quality of the model
Create boundary conditions and systems
The following building processes are described:
Importing geometry
Creating Collectors
Creating Geometry Data
Temporary Nodes
Picking Surfaces
Editing Surfaces
Associativity
Geometry Cleanup
Applying Loads
Creating Systems
Control Cards
Boundary Conditions
Transformation Manager
