Engineering Solutions
Element Quality Calculation: HyperMesh-Alt
HyperMesh includes some alternate methods of calculating certain element types.  These apply only to quads or rectangular faces of solids, and only include alternate checks for Aspect Ratio, Skew, Taper and Warpage.
Note:Because these methods apply only to certain quality checks, in order to use them you must choose the set individually option in the Check Element Settings window.
Aspect Ratio
HM_Alt_AspectRatio
ratio1 = V1/H1
ratio2 = V2/H2
Skew value is larger of ratio1 or ratio2.
Skew
First, HyperMesh constructs lines connecting the midpoints of each edge of the quad (dotted in the picture below).  Next, HyperMesh constructs a third line (green in the picture below) perpendicular to one of the initial lines, then finds the angle between this third line and the remaining initial line--with which is it most likely not perpendicular, unless the quad is a perfect rectangle.
HM_Alt_skew
α is the skew (angle) value.
Taper
First, the quad’s nodes are projected to plane defined by the orthonormal vectors U-V found as follows:
Z = X × Y
V = Z × X
U = X
HM_Alt_taper1
For each corner node, determine a vector from itself to the center of the quadrilateral. These vectors are along the plane formed U-V.
Consider the vertical sides: Calculate vectors along these sides by subtracting the red – dashed vector from that directly above it. This forms the two blue vectors. Find the angle between these blue vectors. Now, do likewise for the horizontal sides. The taper is the largest of these angles.
HM_Alt_taper2
Warpage
This check applies only to quads or rectangular faces of solids.
HM_Alt_Warpage
Warpage = 100 * h / max { Li },
where h is the minimum distance between the diagonals.
See Also:
How Element Quality is Calculated
