Engineering Solutions
Element Quality Calculation: OptiStruct
For the most part, OptiStruct uses the same checks as HyperMesh. However, OptiStruct uses its own method of calculating Aspect Ratio, and it does not support 3D element checks.
Check
Aspect Ratio
OptiStruct defines aspect ratio as the ratio between the minimum and maximum side lengths. 3D elements are evaluated by treating each face of the element as a 2D element, finding the aspect ratio of each face, and then returning the most extreme aspect ratio found.
Chordal Deviation
Chordal deviation of an element is calculated as the largest distance between the centers of element edges and the associated surface. Second order elements return the same chordal deviation as first order, when the corner nodes are used due to the expensive nature of the calculations.
chordal_deviation
Interior Angles
These maximum and minimum values are evaluated independently for triangles and quadrilaterals.
Jacobian
This measures the deviation of an element from its ideal or "perfect" shape, such as a triangle’s deviation from equilateral. The Jacobian value ranges from 0.0 to 1.0, where 1.0 represents a perfectly shaped element.  The determinant of the Jacobian relates the local stretching of the parametric space which is required to fit it onto the global coordinate space.
HyperMesh evaluates the determinant of the Jacobian matrix at each of the element’s integration points (also called Gauss points) or at the element’s corner nodes, and reports the ratio between the smallest and the largest. In the case of Jacobian evaluation at the Gauss points, values of 0.7 and above are generally acceptable. You can select which method of evaluation to use (Gauss point or corner node) from the Check Element Settings window.
Length (min.)
Minimum element lengths are calculated using one of two methods:
The shortest edge of the element.  This method is used for non-tetrahedral 3D elements.
The shortest distance from a corner node to its opposing edge (or face, in the case of tetra elements); referred to as "minimal normalized height".
height2closenode
Skew
Skew of triangular elements is calculated by finding the minimum angle between the vector from each node to the opposing mid-side, and the vector between the two adjacent mid-sides at each node of the element.
patran_skew_tria
The minimum angle found is subtracted from ninety degrees and reported as its skew.
Warpage
This is the amount by which an element (or in the case of solid elements, an element face) deviates from being planar. Since three points define a plane, this check only applies to quads. The quad is divided into two trias along its diagonal, and the angle between the trias’ normals is measured.
hm_warpage
Warpage of up to five degrees is generally acceptable.
See Also:
How Element Quality is Calculated
Element Quality Calculation: HyperMesh
