Engineering Solutions
Entities Export Behavior
This is how the various entities will export out of Engineering Solutions:
Free nodes
Nodes associated to elements are exported. Element export is controlled by the component/group export state that the element is in.
Nodes associated to node dependent systems are exported. System export is controlled by the systemcol export state that the system is in.
Nodes associated to node dependent vectors are exported. Vector export is controlled by the vectorcol export state that the vector is in.
Nodes associated to rigid walls are exported. Rigid wall export is controlled by the group export state that the rigid wall is in.
Nodes on card images of exported entities are exported with those entities. Export of entities is controlled by the export state of that entity (all entities).
Temp nodes are always exported (the ones with the yellow circle).  There is no way to not export these nodes, they always go.
Any node with a non-empty card image are always exported (Example SPOINT). There is no way to not export these nodes, they always go.
Assembly
Do Not Export status: Assembly comments are not exported. If you have components defined within that assembly, you must also change the status to Do Not Export, if and only if, that component does NOT exist in another assembly which is set to Export status. In other words, if that component exists in multiple assemblies and all those assemblies are set to Do Not Export status, then and only then, set the component to Do Not Export status.
Export status: Assembly comments are exported. In addition, when changing the assembly status from Do Not Export to Export, also set any components defined within that assembly to Export status, regardless if that component exists in multiple assemblies.
Component
Do Not Export status: Do not export component comments, component definitions, nodes (see below), elements, connector comments, points, lines, surfaces and solids within that component.
Nodes within components have two options. Internal Nodes are nodes that are NOT shared with any other component. Boundary Nodes are nodes that are shared with other components. Internal nodes are exported based solely on their component export state. Boundary nodes do not export, if and only if all components for which they are in are set to Do Not Export status. If a boundary node exists in any one component set to Export status, then that boundary node is also exported.
Export status: Export component comments, component definitions, nodes (internal and boundary), elements, connector comments, points, lines, surfaces and solids within that component.
Load collector
Do Not Export status: Do not export load collector comments, loads, or equations within that load collector
Export status: Export load collector comments, nodes/elements attached to loads/equations, loads and equations within that load collector
System collector
Do Not Export status: Do not export system collector comments or systems within that system collector
Export status: Export system collector comments, nodes attached to systems and system definitions within that system collector
Vector collector
Do Not Export status: Do not export vector collector comments or vectors within that vector collector
Export status: Export vector collector comments, nodes attached to vectors and vector definitions within that vector collector
BeamSection collector
Do Not Export status: Do not export beam section collector comments or beam section comments within that beam section collector
Export status: Export beam section collector comments and beam section comments within that beam section collector
MultiBody
Do Not Export status: Do not export multibody comments, ellipsoids, multibody planes or multibody joints within that multibody collector
Export status: Export multibody comments, nodes attached to ellipsoids/multibody planes/multibody joints, ellipsoids, multibody planes and multibody joints within that multibody collector
LoadStep
Do Not Export status: Do not export load step comments or load step definitions of the load step
Export status: Export load step comments and load step definition of the load step. The load step export status has NO effect on the export behavior of load collectors, output blocks, or groups associated with the load step.
Output block
Do Not Export status: Do not export output block comments or output block definitions of the output block
Export status: Export output block comments and output block definitions of the output block
Card
Do Not Export status: Do not export card comments or card definition of the card.  This is same as "Disable" on  the Card panel.
Export status: Export card comments and card definitions of the card
Property
Do Not Export status: Do not export property comments or property definitions of the property
Export status: Export property comments and property definitions of the property
Material
Do Not Export status: Do not export material comments or material definition of the material
Export status: Export material comments and material definition of the material
Sets
Do Not Export status: Do not export set comments or set definitions of the set
Export status: Export set comments and set definitions of the set
Blocks
Do Not Export status: Do not export block comments or block definitions of the block
Export status: Export block comments and block definitions of the block
Tags
Do Not Export status: Do not export tag comments or tag definitions of the tag
Export status: Export tag comments and tag definitions of the tag
Titles
Do Not Export status: Do not export title comments or title definitions of the title
Export status: Export title comments and title definitions of the title
Plots
Do Not Export status: Do not export plot comments, plot definitions, curve comments, or curve definitions associated to the plot
Export status: Export plot comments, plot definitions, curve comments and curve definitions associated to the plot
Contact surface
Do Not Export status: Do not export contact surface comments or contact surface definitions of the contact surface
Export status: Export contact surface comments, nodes/elements associated to contact surface or contact surface definitions of the contact surface
Group
Do Not Export status: Do not export group comments or group definitions of the group
Export status: Export group comments, nodes/elements associated with group and group definitions of the group
Sensor
Do Not Export status: Do not export sensor comments or sensor definitions of the sensor
Export status: Export sensor comments and sensor definitions of the sensor
Control volume
Do Not Export status: Do not export  control volume comments or control volume definitions of the control volume
Export status: Export control volume comments and control volume definitions of the control volume
Element
Controlled by component collector export status
Connector
Load
Controlled by load collector export status
Equation
System
Controlled by system collector export status
Vector
Controlled by vector collector export status
Point
Line
Surface
Solid
Beam section
Controlled by beam section collector export status
Ellipsoids
Controlled by multibody collector export status
Multibody planes
Multibody joints
See Also:
Exporting Files
