Engineering Solutions
Gauge File Format and Example
The Gauge file uses the following format:
Number of Gauges
[Number of Gauge Data Lines]
Gauges
Begin                End                Assigned Value
[min Thk]        [max Thk]        [Assigned Thk]
If the Assigned Value is not specified, then the average of the upper and lower limits will be used as Assigned Value.
Below is a specific example of a gauge file:
Number of Gauges
4
Gauges
0.0                0.05                0.05
0.05                0.1                0.1
0.1                0.15                0.15
0.15                0.2                0.2
See Also:
Midsurface Thickness Map
