Midsurf Thickness Behavior Under Different User Profiles |
Organize only
• | Creates new components based on the Organization method. |
• | Organizes elements into these components. |
Contour
• | Creates a contour of the thickness values of nodes and elements, based on the specified options. |
• | If you chose Properties on elements, Properties/Sections on components, or Organize only under the Assign thickness to option, HyperMesh honors the Organization method settings during the contour process and the contour value is assigned based on that organization. This allows the contour to match with the applied results. |
• | If you chose Elements or Properties/Sections on components for the Assign thickness to option, and choose to use Nodal values for the Thickness calculation method, the values may not exactly match the nodal values that are actually applied. There can be multiple thicknesses associated to a node if it shares an edge with multiple surfaces. Since HyperMesh can only provide one value for the contour, it always chooses the first value which might not match exactly with the applied values in these situations. |
• | Creates a single property named tNodalThickness. |
• | Creates a single node set named tNodalThickness with Nodal_Thickness card image. |
• | Assigns the property to the selected 2D elements. |
• | Adds the relevant nodes to the node set. |
• | Assigns a single thickness to each node using attribute ThicknessValue. |
• | Assigns the property to the selected components. |
• | Clears any element property references for any 2D elements in the selected components. |
Properties/Sections on components – nodal values
• | Creates new components based on ordered nodal thickness values. |
• | Creates new properties and sections based on ordered nodal thickness values. Properties are created for those shell elements where thickness is assigned from properties. Shell sections are created for those shell elements where thickness is assigned from shell sections. |
• | Assigns the properties or shell sections to the corresponding components. |
• | Assigns multiple thicknesses to each property, using real values. In case of shell sections, only one thickness will be assigned. |
• | Organizes elements into the corresponding components. |
Properties/Sections on components – all others
• | Creates new properties or shell sections based on the Organization method. Properties are created for those shell elements where thickness is assigned from properties. Shell sections are created for those shell elements where thickness is assigned from shell sections. |
• | Assigns a single thickness to each property or shell section based on the Thickness calculation method, using real values. |
Elements
• | Assigns multiple thicknesses to each element, based on the nodal thickness values for that element: |
- | For tria3 elements, uses attributes: |
Elem_Option
LSD_ELEM_T1
LSD_ELEM_T2
LSD_ELEM_T3
- | For quad4 elements, uses attributes: |
Elem_Option
LSD_ELEM_T1
LSD_ELEM_T2
LSD_ELEM_T3
LSD_ELEM_T4
• | Creates new properties/sections based on the Organization method. |
• | Assigns the properties/sections to the corresponding components. |
• | Assigns a single thickness to each properties/sections based on the Thickness calculation method, using property attribute LSD_T1. |
• | Creates new properties based on the Organization method. |
• | Assigns a single thickness to each property based on the Thickness calculation method, using component attribute TK. |
• | Assigns the properties to the corresponding elements. |
Properties on components
• | Assigns a single thickness to each property based on the Thickness calculation method, using component attribute T. |
Elements
- | For tria elements, uses attributes: |
CTRIA3_T1T2T3
CTRIA3_T1
CTRIA3_T2
CTRIA3_T3
CTRIA3_ZOFFS [if requested]
- | For quad elements, uses attributes: |
CQUAD4_T1T2T3T4
CQUAD4_T1
CQUAD4_T2
CQUAD4_T3
CQUAD4_T4
CQUAD4_ZOFFS [if requested]
• | Turns off the TFLAG option when necessary. |
• | Assigns a single thickness to each properties/sections based on the Thickness calculation method, using property attribute PSHELL_T. |
- | For tria elements, uses z-offset attributes [if requested]: |
CTRIA3_ZOFFS
ZOFFS
- | For quad elements, uses z-offset attributes [if requested]: |
CQUAD4_ZOFFS
ZOFFS
• | Clears any element property references for the selected elements. |
• | Assigns a single thickness to each property based on the Thickness calculation method, using property attribute PSHELL_T. |
- | For tria3 elements, uses z-offset attributes [if requested]: |
CTRIA3_ZOFFS
ZOFFS
CQUAD4_ZOFFS
ZOFFS
Elements
CTRIA3_T1T2T3
CTRIA3_T1
CTRIA3_T2
CTRIA3_T3
CQUAD4_T1T2T3T4
CQUAD4_T1
CQUAD4_T2
CQUAD4_T3
CQUAD4_T4
CTRIA3_ZOFFS
ZOFFS
CQUAD4_ZOFFS
ZOFFS
CTRIA3_ZOFFS
ZOFFS
CQUAD4_ZOFFS
ZOFFS
Elements
• | Assigns a single thickness at the element level based on the Thickness calculation method. |
- | Uses element attribute ELEM_THK. |
Thickness on components
• | Assigns a single thickness to each component based on the Thickness calculation method, using component attribute MAT_THK. |
Properties/Sections on components – Nodal values
• | Creates new properties/sections based on ordered nodal thickness values. |
• | Assigns multiple thicknesses to each properties/sections, using property attributes: |
ThicknessSelEnumField
Thick_value_shell1
Thick_value_shell2
Thick_value_shell3
Thick_value_shell4
• | Assigns a single thickness to each properties/sections based on the Thickness calculation method, using property attributes: |
Thick_value_shell1
Elements
- | Uses element attribute THICK. |
• | Assigns a single thickness to each properties/sections based on the Thickness calculation method, using property attribute THICK. |
