Engineering Solutions
HMDB
HMDB
HMDB
NAME
HMDB - This card points to a material database file for the solver.
SYNTAX
HMDB entitytype, id, name
TYPE
HyperMesh Comments
DESCRIPTION
entity_type
ASSEM, BEAMSECTCOL, BEAMSECTCOLS, BEAMSECTS, BLOCKS,  BLOCKS, CGAPG, COMP, CONNECTOR, CONTACTSURF, CONTROLVOL, CSURF, CURVE,  CWELD, DDVAL, DEQUATIONS, DESVARS, DLINKS, DOBJREF,  DVPRELS, GROUP,  LOADCOL, LOADSTEP, MAT, METADATA, OBJECTIVES, OPTICONSTRAINTS, OPTICONTROLS, OPTIDSCREENS,  OPTITABLEENTRS, OUTPUTBLOCKS, PLOT, PROP, SENSOR, SETS,  SHAPE, SYSCOL, VECTORCOL
id
Unique entity type identification number.
name
A name given by you to help organize the model or describe the entity.
SUPPORTED SOLVERS
OptiStruct
RADIOSS
Abaqus
ANSYS
LS-DYNA
Nastran
PAMCRASH2G
PERMAS
And other miscellaneous solvers
See Also:
HyperMesh Comments
Working with Files
