Engineering Solutions
HMNAME
HMNAME
HMNAME
NAME
HMNAME – An import comment to sort and organize entity types into HM.
SYNTAX
HMNAME entity_type id name
TYPE
HyperMesh Comments
DESCRIPTION
entity_type
BEAMSECTCOL, BEAMSECT, BLOCK, CGAPG, CONNECTOR, CONTACTSURF, CONTROLVOL, CSURF, CURVE,  CWELD, DDVAL, DEQUATIONS, DESVARS, DLINKS, DOBJREF,  DVPRELS, LOADCOL, LOADSTEP, METADATA, OBJECTIVES, OPTICONSTRAINTS, OPTICONTROLS, OPTIDSCREENS,  OPTITABLEENTRS, OUTPUTBLOCKS, PLOT, SENSOR, SHAPE, SYSCOL, VECTORCOL
id
Unique entity type identification number.
name
A name given by you to help organize the model or describe the entity.
SUPPORTED SOLVERS
OptiStruct
RADIOSS
Abaqus
ANSYS
LS-DYNA
Nastran
PAMCRASH 2G
PERMAS
And other miscellaneous solvers
See Also:
HyperMesh Comments
Working with Files
