Engineering Solutions
HMNAME COMP
HMNAME COMP
HMNAME COMP
NAME
HMNAME COMP – An import comment to sort and organize entity types into HM.
SYNTAX
HMNAME COMP id name property_id property_name id_pool
TYPE
HyperMesh Comments
DESCRIPTION
entity_type
COMP
id
Unique entity type identification number.
name
A name given by you to help organize the model or describe the entity.
property_id
Unique entity type identification number. Valid only for OptiStruct and Nastran.
property_name
A name given by you to help describe the entity. Valid only for OptiStruct and Nastran.
id_pool
Internal solver ID pool. Valid only for OptiStruct and Nastran.
SUPPORTED SOLVERS
OptiStruct
RADIOSS
ANSYS
LS-DYNA
Nastran
See Also:
HyperMesh Comments
Working with Files
