Engineering Solutions
HMREFSYSTEM
HMREFSYSTEM
HMREFSYSTEM
NAME
HMREFSYSTEM – Used to re-associate nodes/systems with their local systems.
SYNTAX
HMREFSYSTEM type id system_id
TYPE
HyperMesh Comments
DESCRIPTION
Some solver codes do not support nodes or coordinate systems created in or referencing local coordinate systems. If you define a block of comments at the end of the deck, you can re-associate the nodes/systems with their local coordinate systems.
type
The five-character name of the entity type, either NODES or SYSTS.
id
The HyperMesh ID of the node/system referencing the system, a 10-character integer.
System_id
The HyperMesh ID of the coordinate system, a, 10-character integer.
SUPPORTED SOLVERS
See Also:
HyperMesh Comments
Working with Files
