Engineering Solutions
HWCOLOR
HWCOLOR
HWCOLOR
NAME
HWCOLOR – An import comment to color an entity in HM.
SYNTAX
HWCOLOR entity_type id color_id
TYPE
HyperMesh Comments
DESCRIPTION
An import comment to color an entity in HyperMesh.
entity_type
ASSEM, BEAMSECTCOL, BEAMSECTCOLS, BEAMSECTS, BLOCKS,  BLOCKS, CGAPG, COMP, CONNECTOR, CONTACTSURF, CONTROLVOL, CSURF, CURVE,  CWELD, DDVAL, DEQUATIONS, DESVARS, DLINKS, DOBJREF,  DVPRELS, GROUP,  LOADCOL, LOADSTEP, MAT, METADATA, OBJECTIVES, OPTICONSTRAINTS, OPTICONTROLS, OPTIDSCREENS,  OPTITABLEENTRS, OUTPUTBLOCKS, PLOT, PROP, SENSOR, SETS,  SHAPE, SYSCOL, VECTORCOL
id
Unique entity type identification number.
color_id
A color identification number from the HM color palate.
SUPPORTED SOLVERS
OptiStruct
RADIOSS
Abaqus
ANSYS
LS-DYNA
Nastran
PAMCRASH2G
PERMAS
And other miscellaneous solvers
See Also:
HyperMesh Comments
Working with Files
