Engineering Solutions
I-DEAS to RADIOSS
I-DEAS to RADIOSS
I-DEAS to RADIOSS
The I-DEAS to RADIOSS converter utility will convert an I-DEAS input file to a OptiStruct input file.
Follow these steps to perform a conversion.
1.Select an I-DEAS file as the source file, or check the Use current HM model box to use the model loaded in the current session.
2.Select a file name and location to save the OptiStruct file that will be generated, or check the Apply to current HM session only box to generate the OptiStruct model in the current session.
3.Click Convert.
See Also:
Utility Menu
