The following macros are available on the FEA page of the OptiStruct Utility menu:
Auto Property Creation |
If two or more components points to single property this utility will create a separate property for each component. |
Converters |
Convert from I-DEAS to OptiStruct |
Export bodies (groups) and joint to an MDL (Model Definition Language) file to be read into MotionView. |
Model Info |
Create, review and edit materials |
Create, review and edit components |
Create, review and edit properties |
Review and edit load collectors |
Tools |
Launches the Curve Editor |
Create a tabular function card. |
Create one or more contact interfaces at once between several parts of your model. |
Create and edit 1D and 3D pretension bolt loads and bolt sections for the OptiStruct solver. |
LoadSteps |
Generate OptiStruct subcase definitions. |
Create a linear buckling subcase and referenced static subcase. |
Fatigue Process |
Create New |
Launches the Fatigue Process Manager Browser, and starts a new fatigue analysis setup process. |
Load Existing |
Launches the Fatigue Process Manager Browser, and loads a fatigue analysis setup process that has been previously saved to a file. |
Solution |
OptiStruct |
Shortcut to the OptiStruct panel. |
RADIOSS |
Shortcut to the RADIOSS panel. |
