Engineering Solutions
Pretension Manager
Pretension Manager
Pretension Manager
Location:   Utility Browser and Tools menu > Pretension Manager. This tool is only available when the OptiStruct user profile is loaded.
The Pretension Manager tool allows you to create and edit 1D and 3D pretension bolt loads and bolt sections for the OptiStruct solver. For details on how the pretensioned bolt analysis works inside of OptiStruct, please refer to Pretensioned Bolt Analysis in the OptiStruct online help.
Pretensionmanagerdialog
Pretension Manager Dialog
The Pretension Manager uses a table format to display all the bolt pretension loads in the model. Each row represents a pretension load in the model, and each column represents the following:
Column
Related OptiStruct Card(s)
Bolt Type
Displays the type of bolt the load is applied to. Can be 1D or 3D.
PRETENS
Bolt Id
Displays the identification number of the Bolt Pretension section the load is applied to.
PRETENS
EID/SURFID
Displays the Element (1D) or Surface (3D) identification number where the Bolt Pretension section is located.
PTFORCE, PTADJST
Load Type
Allows you to review and edit the type of pretension load, by selecting one of the following options from the pull-down menu:
Force
Adjustment
Use the CTRL key to select and edit this field in multiple rows at once.
Click OK or Apply to update the load types in the model. Click Cancel to exit the Pretension Manager without saving any changes.
PTFORCE, PTADJST
Loadcol
Allows you to review and edit the Load Collector where the pretension load is organized in HyperMesh, by selecting one of the following options from the pull-down menu:
Select Existing: Takes you to the Load Collector Selector panel.
Create New: Automatically creates a new Load Collector with the name prefix PRETENS_* to organize the load into.
PTFORCE, PTADJST
Load Id
Displays the HyperMesh internal identification number of the individual loads.
Load Magnitude
Allows you to review and edit the pretension load magnitude.
Use the CTRL key to select and edit this field in multiple rows at once. Enter a new value and press ENTER to apply the changes  to all of the selected rows.
PTFORCE, PTADJST
Orientation
(Optional) Allows you to review and edit the determination type of the normal direction of the bolt pretension section, by selecting one of the following options from the pull-down menu:
Blank: Solver default
AUTO
GRIDS: Takes you to a G1,G2,G3 node selection dialog.
VECTOR: Takes you to the Direction Selector panel.
CID: Takes you to the System Selector panel.
The Orientation type value will be updated in the model immediately after editing the selection.
Output DOF ID
(Optional) Allows you to review and edit the SPOINT that contains the pretension deformation and load, by selecting one of the following options from the pull-down menu:
Select Existing: Takes you to the Node Selector panel.
Create New: Automatically creates a new SPOINT and assigns it to the bolt pretension section.
The Output DOF ID value will be updated in the model immediately after editing selection.
PRETENS
The Pretension Manager dialog contains the following buttons:
Button
Add 1D Bolts
Allows you to create one or more 1D Bolt Pretension sections.
To add a 1D Bolt Pretension section:
1.Clicking the Add 1D Bolts button.
The Element Selector panel opens.
2.Select one or more beam, bar or rod elements.
3.Click Select.
4.Click Proceed.
The individual 1D Bolt Pretension sections will be created for each selected element.
Add 3D Bolts
Allows you to create one or more 3D bolt Pretension Sections. Two options are available when you click the Add 3D Bolts button:
Select Existing Surface: Takes you to the Contact Surface Selector panel, where you can select existing surfaces. Once you click Select and Proceed, the individual 3D bolt Pretension Sections will be created for each selected contact surface.
Create New Surface: Takes you to the Contact Surface Create (solid faces) panel, where you need to select elements and face nodes to create the surface for the bolt pretension section, as depicted in the images below:
Step 1:     Select elements on one side of the bolt:
pretensionmanager1
Step 2:     Select nodes on the section face:
pretensionmanager2
When you are using the Create New Surface option, a default name will be automatically assigned in the panel using the prefix PRETENS_* and the appropriate card image. Once you click Create and Return, you will be brought back to the Pretension Manager.  The Pretension Manager will now display a 3D Bolt Pretension section for the new contact surface.
Add Load
Allows you to add a new pretension load to an existing Bolt Pretension section.
To add a new pretension load to an existing Bolt Pretension section:
1.Click the checkbox's, in the first column, for the Bolt Pretension section that you want to add a new load to.
2.Click the Add Load button to add the new load to the selected Bolt Pretension section.
The new load will be added directly below the section you wanted to add the new load to, and organized using a hierarchical tree-like display fashion (see the View button below for more options).
Example:
The model below has four Bolt Pretension sections with IDs 1, 2, 3 and 4, and the pretension Force loads of 9500, 10000, 11500, and 9000 are applied to them, respectively.
pretensionmanager3
An additional pretension Adjustment load of 0.1 needs to be applied to Bolt Sections 3 and 4 only. To do this, you must select the checkbox's for sections 3 and 4 (as shown above), and then click the Add Load button. One additional pretension load is added below each of the selected bolt sections.
pretensionmanager4
Looking at the left side of the table, it is easy to see that there are only four Pretension Bolt sections in the model, however, some of them have more than one pretension load applied to them.
In this example, the Force loads on all bolts are organized into Load Collector PRETENS_1, while the Adjustment loads on Bolts 3 and 4 are organized into a different Load Collector PRETENS_2, which allows them to be used in a different Load Step if desired.
Delete
Deletes the selected bolt pretension sections and/or pretension loads.
To delete selected bolt pretensions section:
1.Click the checkbox's, in the first column, for the rows you wish to delete.
2.Click the Delete button.
When a Bolt Pretension section has more than one load applied to it, deleting the bolt section at the top level will automatically delete all the loads applied to it. On the other hand, deleting single additional loads will only remove the selected loads.
Review
Allows you to graphically review the Element/Surface, Load, and SPOINT assigned to the selected Bolt Pretension section. This button also displays more detailed information about the selected Bolt Pretension section's Orientation.
To review a Bolt Pretension selection:
1.Click checkbox's, in the first column, for the Bolt Pretension section you wish you review.
2.Click Review.
The Review Pretension dialog appears.
3.Click OK in the Review Pretension dialog to return to the Pretension Manager dialog.
Select All
Select all rows in the table.
Select None
Deselect all rows in the table.
Select Reverse
Reverses row selection in the table.
View
Controls the Pretension Manager table's view organization mode. There are two options available from the pull-down menu:
By Bolt (default): Multiple loads applied to the same Pretension Bolt section are displayed directly below it, organized using a hierarchical tree-like display structure.
pretensionmanager5
All: Multiple loads applied to the same Pretension Bolt section are displayed directly below it, using a flat display structure with no hierarchical organization. The Bolt Pretension section's Type and ID are displayed for all pretension loads in the model.
pretensionmanager6
See Also:
