Engineering Solutions
IGES Reader Support
IGES Reader Support
IGES Reader Support
The following entities are supported by the IGES reader:
Circular arc (100)
Composite curve (102)
Conic arc (104)
Copius data (106)
Plane (108)
Line (110)
Parametric spline curve (112)
Parametric spline surface (114)
Point (116)
Ruled surface (118, form 1 only)
Surface of revolution (120)
Tabulated cylinder (122)
Direction (123)
Transformation matrix (124)
Flash (125)
Rational B-spline curve (126)
Rational B-spline surface (128)
Offset surface (140)
Boundary (141)
Curve on a parametric surface (142)
Bounded surface (143)
Trimmed (parametric) surface (144)
Manifold solid B-rep object (186)
Plane surface (190)
Right circular cylindrical surface (192)
Right circular conical surface (194)
Spherical surface (196)
Toroidal surface (198)
Angular dimension (202)
Diameter dimension (206)
General label (210)
General note (212)
Leader (214)
Linear dimension (216)
Radius dimension (222)
General symbol (228)
Sectioned area (230)
Line font definition (304)
Subfigure definition (308)
Color definition (314)
Form 7 group without back pointers (402)
Drawing (404)
Form 15 name (406)
Singular subfigure instance (408)
View (410)
Vertex (502)
Edge (504)
Loop (508)
Face (510)
Shell (514)
See Also:
CAD Reader Support
IGES Import Options
