Engineering Solutions
Inspire Reader Support
The Inspire reader supports .stmod files. The following entities are supported by the Inspire reader:
Models
Assemblies
Parts
Solids
Sheets
Curves
Points
Visibility
Color
Transparency
Alternatives
oActive alternatives are imported by default.
oAll alternatives are imported when hidden (blanked/no show) entities are imported.
Active status
oActive geometry is imported by default.
oAll geometry is imported when hidden (blanked/no show) entities are imported.
See Also:
CAD Reader Support
Inspire Import Options
