Engineering Solutions
Inspire Import Options
The Inspire reader use the inspire_reader.ini file with the following available options:
@CleanupTol
Value
double
A negative value (default) means to use the auto cleanup tolerance.  A value greater than the calculated auto cleanup tolerance means to use that specific tolerance.
Refer to the CAD Cleanup Tolerance section.
@ColorsAsMetadata
Value
integer
Read color attributes of geometric entities as metadata.
COLOR_RGB
on
COLOR_RGB
off
Do not read color attributes (default).
@DensityAsMetadata
Value
on
Read density value as metadata (default).
DENSITY
off
Do not read density value.
@DoNotMergeEdges
Value
on
Preserve the original geometry edges, instead of merging them together during the import cleanup phase.
off
Merge edges together during the import cleanup phase (default).
@ExtractManifoldFromGeneralBody
Value
on
Extract the manifold body from a Parasolid general body that is non-manifold and/or of mixed topological dimensionality (default).
off
Extract Parasolid general bodies as defined.
@ImportBlanked
Value
on
Import entities that are hidden, blanked, or no show.
off
Do not import entities that are hidden, blanked, or no show (default).
@ImportForVisualizationOnly
Value
on
Import the model for visualization purposes only.
This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.
off
Import the model in the normal fashion (default).
@ImportFreeCurves
Value
on
Import free curves (wireframe entities) into the model (default).
off
Do not import free curves.
@ImportFreePoints
Value
on
Import free points into the model (default).
off
Do not import free points.
@MetadataPrefix
Value
string
The string is prefixed to all metadata names. No prefix is used by default.
See CAD Metadata Naming for more details.
@OriginalIdAsMetadata
Value
on
Import original Inspire and Parasolid entity IDs as metadata.
off
Do not import original Inspire and Parasolid entity IDs as metadata (default).
@ScaleFactor
Value
double
Defines the model scaling factor during import.
Default is 1.0.
@SkipCreationOfSolid
Value
on
Read surfaces, but do not create solid entities.
off
Create solid entities (default).
@SplitPeriodicFaces
Value
on
Split periodic surfaces to improve the quality and robustness of the import (default).
off
Import periodic surfaces as a single surface with a seam edge.
@UniqueIdAsMetadata
Value
on
Create metadata to track the unique CAD entity IDs. The ID is a combination of the Inspire body ID and the Parasolid entity ID, in order to make it unique.
UNIQUE_ID
off
Do not create metadata to track the unique CAD entity IDs (default).
See Also:
Inspire Metadata Support
Inspire Reader Support
CAD Import Options
