Engineering Solutions
Inspire Metadata Support
The Inspire reader generates the following metadata:
COLOR_RGB
Entities
string
points
lines
surfs
solids
Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model.
Generated when @ColorsAsMetadata = on
DENSITY
Entities
double
solids
The value of the density of a solid.
Generated when @DensityAsMetadata = on
MODELUNIT
Entities
integer
comps
The model units specified in the CAD file.  Values include:
1 = inches
2 = millimeters
4 = feet
5 = miles
6 = meters
7 = kilometers
8 = mils
9 = microns
10 = centimeters
11 = microinches
12 = decimeters
13 = yards
This is always generated.
ORIGINAL_ID
Entities
string
comps
points
lines
surfs
solids
The original Inspire ID for comps and the Parasolid entity IDs for the geometry.
Generated when @OriginalIdAsMetadata = on
UNIQUE_ID
Entities
string
points
lines
surfs
solids
A combination of the Inspire body ID and the Parasolid entity ID.
See Also:
Inspire Import Options
Inspire Reader Support
CAD Import Options
hm_metadata
