Engineering Solutions
Intergraph Import Options
The Intergraph reader uses the intergraph_reader.ini file with the following available options:
@AssignPropertiesToComponents
Value
on
Assign properties to the corresponding component (for components which have more than one property, properties are not assigned).
off
Do not assign properties to components (default).
@CleanupTol
Value
double
A negative value (default) means to use the auto cleanup tolerance.  A value greater than the calculated auto cleanup tolerance means to use that specific tolerance.
Refer to the CAD Cleanup Tolerance section.
@CreateMetadataForStiffenerNormals
Value
on
Attach some metadata with info about normals to stiffener/beam/ER systems (see Intergraph Metadata Suppport).
off
Do not attach metadata with info about normals to stiffeners/beam/ER systems (default).
@CreateMultipleComponentsForLinearMembers
Value
on
Create one component for each member part (default).
off
Group member parts belonging to the same member system based on thickness and diameter (that is, just one component is created for each set of data).
@CreateMultipleComponentsForStiffeners
Value
on
Create one or more components for each stiffener/beam/ER geometry (one for each property; that is, if we have flange and web, then two different properties and components are created) (default).
off
Group stiffener/beam/ER geometries belonging to the same root stiffener/beam/ER system based on their properties (that is, just one component is created for each set of property data).
@DoNotMergeEdges
Value
on
Preserve the original geometry edges, instead of merging them together during the import cleanup phase.
off
Merge edges together during the import cleanup phase (default).
@ImportCompartments
Value
on
Import both compartments in the IGES files, and compartments defined by “Faces”. The former by importing the geometry, the latter just by creating a metadata (see Intergraph Metadata Suppport); also reference planes are created, because they can be referenced by compartments.
off
Do not import any compartments (default).
@ImportIGESCompartments
Value
on
Import compartments in the IGES files.
off
Do not import any compartments in the IGES files (default).
@ImportPlateSystemMetadata
Value
on
Create physical properties assigned in the XML to plate systems and bracket children as metadata.
off
Do not import physical properties assigned in the XML to plate systems and bracket children (default).
@ImportStiffenerMidSurfaces
Value
on
Create stiffener/beam/ER midsurfaces (instead of solid geometry) in both global and local analysis; also create landing curves in global analysis.
off
Create stiffener/beam/ER solid geometry in local analysis, and landing curves in global analysis (default).
@ImportTopologicalProperties
Value
on
Do not import topological property (default).
off
Create reference planes and sketch contours, and attach metadata to the systems which own these properties (see Intergraph Metadata Suppport).
@MetadataPrefix
Value
string
Prefix the string to all metadata names. By default, no prefix is used.
See CAD Metadata Naming for more details.
@PropertyName
Value
string
Name of the properties created in HyperMesh. It can contain “special” strings that will be replaced with their meaning: <COMPONENT_NAME> is the name of the component to which the property is associated, <PROPERTY_CARD_NAME> is the name of the property card.
@ScaleFactor
Value
double
Defines the model scaling factor during import.
Default is 1.0.
@Solver
Value
string
Use to choose the solver for which materials and properties are created; currently this string can be “nastran” or “ansys”; the default solver is Nastran.
@StiffenerJustCurves
Value
on
Create only landing curves for stiffeners.
off
Create the complete stiffener geometry (default).
See Also:
Intergraph Metadata Support
Intergraph Reader Support
CAD Import Options
