Engineering Solutions
IGES Metadata Support
The IGES reader generates the following metadata:
AUTHOR
Entities
string
comps
The author block as read from the 'G' section of the file.  This is generated only when the block is found in the file.
AUTHORS_ORGANIZATION
Entities
string
comps
The author's organization block from the 'S' section of the file.  This is generated only when the block is found in the file.
COLOR_RGB
Entities
string
lines
surfs
Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model.
Generated when @ColorsAsMetadata = on
COMMENT_BLOCK
Entities
string
comps
The comment block from the 'S' section of the file.  This is generated only when the block is found in the file.
DRAFTING_STANDARD
Entities
integer
comps
The drafting standard block from the 'G' section of the file.  This is generated only when the block is found in the file.
GROUP_ID
Entities
integer
comps
The IGES entity type #402, form number #7 group ID as read from the CAD model, if one exists.
Generated when @PropertyAsGroup = ManageCorrectOnly
GROUP_NAME
Entities
string
comps
The IGES entity type #402, form number #7 group name as read from the CAD model, if one exists.
IGES_VERSION
Entities
integer
comps
The IGES version block from the 'G' section of the file.  This is generated only when the block is found in the file.
FILE_NAME
Entities
string
comps
The file name block from the 'G' section of the file.  This is generated only when the block is found in the file.
IMPORT_DATE
Entities
string
comps
The import date block from the 'G' section of the file.  This is generated only when the block is found in the file.
MODELUNIT
Entities
integer
comps
The model units specified in the CAD file.  Values include:
1 = inches
2 = millimeters
4 = feet
5 = miles
6 = meters
7 = kilometers
8 = mils
9 = microns
10 = centimeters
11 = microinches
12 = decimeters
13 = yards
This is always generated.
MODIFICATION_DATE
Entities
string
comps
The modification date block from the 'G' section of the file.  This is generated only when the block is found in the file.
PREPROCESSOR_VERSION
Entities
string
comps
The preprocessor version block from the 'G' section of the file.  This is generated only when the block is found in the file.
PRODUCT_IDENTIFICATION
Entities
string
comps
The product identification block from the 'G' section of the file.  This is generated only when the block is found in the file.
RECEIVING_PRODUCT_ID
Entities
string
comps
The receiving product ID block from the 'G' section of the file.  This is generated only when the block is found in the file.
SYSTEM_ID
Entities
string
comps
The system ID block from the 'G' section of the file.  This is generated only when the block is found in the file.
TAG
Entities
string
points
lines
surfs
The tag (name) of the entity as read from the CAD model, if one exists.
Generated when @TagsAsMetadata = on
UNITS
Entities
string
comps
The units block from the 'G' section of the file.  This is generated only when the block is found in the file.
See Also:
IGES Import Options
IGES Reader Support
CAD Import Options
