Leak detection mesh controls check if the resulting wrapped surface mesh creates a desired cavity before the wrapping process starts. For example, for an external aero/underhood analysis, leak detection mesh controls can help make sure a cabin, engine, and fuel tank are properly sealed, prohibiting mesh from being created there.
Once leak detection mesh controls are defined, right-click on the Adaptive Wrap folder and select Run Leak Detection. Depending upon the model size and parameters defined, leak detection can take several minutes.
Parameter |
Description |
Enclosed Node |
Defines the node within shells to be enclosed by the wrapper. This node should be enclosed by a possible volume. |
Destination Nodes |
Destination nodes enable leak detection paths to be found between the enclosed node and destination nodes. 1D elements are generated to show the leak detection path. If a leak detection path is not found, 1D elements will not be generated. |
