Proximity mesh controls define element refinement based on proximity. Use proximity mesh controls to avoid contact between selected components and any refinement gaps between them.
Global and local proximity mesh controls can be defined. Global proximity mesh controls can only be created from the Adaptive Wrap > Model > Refinement section, whereas local proximity mesh controls can only be created from the Adaptive Wrap > Proximity section.
Parameter |
Description |
Group Selection |
Determines how proximity is defined.
Proximity Tolerance |
Resolves all proximity above this value. |
Self Proximity |
Refines the proximity of elements within one component above the Proximity Tolerance. Only available when Group Selection is set to Within Group. |
