Engineering Solutions
Using the Card Previewer
A control card may be in one of three states:
State
Color
Explanation
Undefined
Gray
The control card was either never created or has been deleted.
Defined
(See note.)
Green
Any control card viewed in the card previewer is activated.
Inactive
Red
A card that has been defined may be disabled.  The attributes for that card remain; however, the control card is not output.
Note:Those control cards that are defined (green in the control card editor) are output.
Default values for attributes are common throughout the card previewer.  A default value field has two states:
State
Default = ON
In this state, the field label color is yellow and no data entry is allowed.
Default = OVERRIDDEN
To override a default value field, pick the yellow field label.  When you override a default value field, the label text color changes to cyan and allows you to enter data in the field.
