Engineering Solutions
Nastran to Abaqus Conversion
The Nastran To Abaqus tool uses an open conversion scheme; you can specify different mappings in the configuration file. Care has to be taken so that the element and property mappings are consistent. Altair provides a valid mapping scheme in the ConfigurationFile.txt. This document explains the scope and limitations of the mapping scheme.
Use the Conversion tool to convert a Nastran file to an Abaqus file.
1.Load the Nastran user profile.
2.Import a Nastran model.
3.To run the Conversion macro, from the menu bar, click Tools > Convert > Nastran > To Abaqus. The Conversion tab opens.
4.To enabled additional conversion options, click Conversion Options.
Convert Rigid Element to Hinge
Any rigid element with one of the degree of freedom left free during conversion will be converted as a hinge element when this option in enabled.
Define Direction Cosines in Property after conversion for PBar, PBeam, PBarl, PBeamL
5.To start the conversion, click convert. After the conversion, the Abaqus user profile automatically loads.
6.Review and export the deck using the Abaqus user profile. Some of the keywords in the Nastran deck are converted to the Abaqus deck as per the following tables.
Elements
HyperMesh elements have two basic attributes – configuration (or config) and type. The "config" defines the basic geometrical shape of an element. For example, tria3 configuration is a 3 node triangular element and hexa8 is an 8-node hexahedral element. The "type" defines the solver-specific element type of a particular configuration. For example, the 4-node quadrilateral (quad4) element in Abaqus can be any of the following types: S4, S4R, M3D4, R3D4, and so on. The Elem Types panel shows all supported element configs and their types for a user profile.
For a specific configuration, you can map any supported Nastran element type to any supported Abaqus element type. Several 2-noded element configurations such as spring, rigid, bar2, rid, and so on are supported. Because all of them are 2-noded elements, conversion across these configurations is also allowed for some element types.  For example, CBUSH is of "spring" config in the Nastran user profile and CONN3D2 is of ‘rod" config in the Abaqus user profile. It is possible to map a CBUSH to CONN3D2 even though their configs are different. The element mapping scheme must be under the *ElemTypeConversion block in the ConfigurationFile.txt file. You need to provide both config and type information to specify the element mapping scheme as shown below:
HM configuration,
Nastran type
HM configuration,
Abaqus type
tria3, CTRIA3
tria3, S3
tria3, CTRIAR
tria3, S3R
quad4, CQUAD4
quad4, S4
quad4, CQUADR
quad4, S4R
quad4, CSHEAR
quad4, M3D4
tetra4, CTETRA
tetra4, C3D4
penta6, CPENTA
penta6, C3D6
hex8, CHEXA
hex8, C3D8
tria6, CTRIA6
tria6, STRI65
quad8, CQUAD8
quad8, S8R
tetra10, CTETRA
tetra10, C3D10
penta15, CPENTA
penta15, C3D15
hex20, CHEXA
hex20, C3D20
mass, CONM2
mass, MASS
mass, CELAS1
mass, SPRING1
mass, CELAS2
mass, SPRING1
rigid, RBE2
rigid, COUP_KIN
rigidlink, RBE2
rigidlink, COUP_KIN
rbe3, RBE3
rbe3, COUP_DIS
spring, CELAS1
spring, SPRING2
spring, CELAS2
spring, SPRING2
spring, CDAMP1
spring, DASHPOT1
spring, CDAMP2
spring, DASHPOT2
spring, CBUSH
rod, CONN3D2
bar2, CBEAM
bar2, B31
bar2, CBAR
bar2, B31
rod, CROD
rod, T3D2
rod, CONROD
rod, T3D2
gap, CGAP
gap, GAPUNI
weld, RBAR
rigid, KINCOUP
Notes:
The CELAS1 or CELAS2 elements in Nastran have both spring stiffness and damping attributes. If both spring and damping values are present and the mapping scheme is CELAS1 to SPRING1, the conversion tool will automatically create an extra DASHPOT element.
Similarly, the CONM2 elements in Nastran have both translational and rotational mass values. If both translational and rotational values are present and the mapping scheme is CONM2 to MASS, the conversion tool will automatically create an extra ROTARY1 element.
*COUPLING/*KINEMATIC constraints with element based surfaces (currently mapped to groups in HM) are converted into rigid elements. Currently conversion of *COUPLING/*DISTRIBUTING with element based surfaces is not supported.
The configuration file can be updated such that config can be changed to DCOUP3D for Rbe3 with COUP_DIS as the default conversion.
In the Nastran to Abaqus Conversion browser, the conversion option Define Direction Cosines in Property after conversion for PBar, PBeam, PBarL, and PBeamL is selected by default. If your provided direction cosines for beams in Nastran then this option will transfer this information to *Beam Section in Abaqus.
Sectional Properties
The table below shows supported sectional property mapping between Nastran and Abaqus. Some of the properties in one solver can be converted to two different Abaqus sections in the other solver. For a Nastran to Abaqus conversion, for example, PSHELL can be converted to *SHELL SECTION or *SHELL GENERAL SECTION. In the mapping scheme, you must select one of them. The property mapping scheme must be under the *PropertyConversion block in the ConfigurationFile.txt file.
Abaqus beam section axes are defined at the element level in Nastran. They are in the sectional property level in Abaqus unless the beam axis is defined by a third node in element connectivity. This means that several elements with different beam axis directions can point to the same PBEAM, PBEAML, PBAR or PBARL property in Nastran. But in Abaqus, all elements under a *BEAM SECTION or *BEAM GENERAL SECTION property have one beam axis orientation. If a third node is used to define the beam axis, even Abaqus beams with a different axis can belong to a single *BEAM SECTION property. Use the conversion tool to select an extra (1 or 0) argument to define the beam axis conversion mechanism.
If the argument is 0 (or not defined), the conversion tool will take the beam axis direction of the first element corresponding to a PBEAM, PBEAML, PBAR or PBARL property and map that to the corresponding *BEAM SECTION or *BEAM GENERAL SECTION card. The beam axis vectors of other elements with the same property will be ignored.
If the argument is 1, the conversion tool will create a third node for each element to define the equivalent beam axis vector. As a result, the axis direction for each element will be maintained after the conversion. Because this option updates each element, the conversion process might take a considerable amount of time for models with a large number of beams.
The system for CELAS1 or CELAS2 elements is sitting on the grid nodes. Thus, every element can have a different system. Ideally, on conversion one *SPRING (and *DASHPOT) or *CONNECTOR SECTION per element needs to be created. For large models this can be time-consuming.
Therefore for CELAS1 two options can be set in the ConfigurationFile.txt (1 or 0). If the option is 1, one property per element will be created (default). If the flag is set to 0, one property per PELAS card will be created. In this case, the settings of the first element found on this property will be translated. From CELAS2 elements you always create a *SPRING and *DASHPOT or *CONNECTOR SECTION property per element.
Nastran
Abaqus
Beam axis option
PSOLID
*SOLID SECTION
PSHELL
PBEAM
1 or 0
PBEAML
*BEAM SECTION
1 or 0
PBAR
1 or 0
PBARL
*BEAM SECTION
1 or 0
PROD
*SOLID SECTION
PBUSH
*CONNECTOR SECTION
PBUSHT(KN)
*CONNECTOR PLASTICITY
PELAS
(*SPRING + *DASHPOT) or *CONNECTOR SECTION
1 or 0
PDAMP
CELAS2
CDAMP2
CONM2
(*MASS +*ROTARY INERTIA)
Notes:
CELAS2, CDAMP2 and CONM2 are elements in Nastran, but they are sectional properties in Abaqus. Therefore, the mapping for them must also be defined under *PropertyConversion.
The PELAS or CELAS2 in Nastran have both spring stiffness and damping attributes. If both spring and damping values are present and they are mapped to *SPRING, the conversion tool will automatically create an extra *DASHPOT property. The elements will both be kept in the same component and the property will be directly assigned to the *SPRING or *DASHPOT element.
Similarly, the CONM2 in Nastran has both translational and rotational mass values. If both translational and rotational values are present and it is mapped to *MASS, the conversion tool will automatically create an extra *ROTARY INERTIA component.
The property conversion scheme and corresponding element conversion scheme must be consistent. For example, if you define PBUSH to *CONNECTOR SECTION at the property mapping scheme, the corresponding element CBUSH must map to CONN3D2 in the element mapping scheme.
A Nastran model with PBUSHT KN referencing TABLED1 is converted to CONNECTORSECTION & CONNECTOR_BEHAVIOR ,and TABLED1 is mapped to CONNECTOR PLASTICITY.
Materials
The table below shows supported material mapping between Nastran and Abaqus. The material mapping scheme must be defined under *PropertyConversion block in the ConfigurationFile.txt file.
Nastran
Abaqus
MAT1
*MATERIAL
*ELASTIC, TYPE=ISO; *EXPANSION, TYPE=ISO; and *DENSITY (G is used only for *BEAM GENERAL SECTION)
MAT2
*MATERIAL
When used alone in a PSHELL, MAT2 is translated to *ELASTIC, TYPE=LAMINA or *ELASTIC, TYPE=ANISOTROPIC
MAT8
*MATERIAL
ELASTIC, TYPE=LAMINA; *EXPANSION, TYPE=ORTHO; and *DENSITY
MAT9
*MATERIAL
*ELASTIC, TYPE=ANISOTROPIC unless the data are found to be orthotropic, in which case the data are analyzed to create *ELASTIC, TYPE=ENGINEERING CONSTANTS. Also *DENSITY; and *EXPANSION, TYPE=ANISO or ORTHO.
Note:If a PBEAM or PBAR is mapped to a *BEAM GENERAL SECTION, the material properties defined in the corresponding Nastran material are mapped to the *BEAM GENERAL SECTION card. No *MATERIAL is created in this case.
Loads
HyperMesh loads have two basic attributes – configuration (or config) and type. The supported load "configs" are: force, moment, constraint, pressure, temperature, flux, velocity, acceleration and equation. The load "type" defines the solver specific type of a particular configuration. For example, pressure load can be any of the following Abaqus types: DLOAD, FILM, DFLUX, and so on. The Load Types panel shows all supported load configurations and their types for a user profile.
The converter also converts distributed surfaces loads (*DLSOAD) applied on faces of shell or solid elements into pressure loads (PLOAD4).
The SPC load collectors referenced in SPCADD will have INITIAL_CONDITION as its card image on conversion.
The LOAD cards referenced in LOADADD will be attached to all of the load steps in the model on conversion.
For a specific configuration, you can map any supported Nastran load type to any supported Abaqus load type. The conversion tool does not support conversion across load configurations. The load mapping scheme is valid for either direction and must be under the *BCsTypeConversion block in the ConfigurationFile.txt file. You need to provide both configuration and type information to specify the mapping scheme as shown below:
HM configuration,
Nastran type
HM configuration,
Abaqus type
force, FORCE
force, CLOAD
moment, MOMENT
moment, CLOAD
const, SPC
const, BOUNDARY
const, SPCD
const, VELOCITY
const, SUPORT
const, BOUNDARY
Const,TIC(V)
velocity, VELOCITY
pressure, PLOAD
pressure, DLOAD
pressure, PLOAD2
pressure, DLOAD
pressure, PLOAD4
pressure, DLOAD
temp, TEMP
temp, TEMPERATURE
equation, MPC
equation, EQUATION
In addition to the above load types, the conversion tool also converts Nastran Dload (with corresponding Rload1, Rload2, DAREA, TABLED1, TABLED2, TABLED3) to Abaqus *BOUNDARY or *CLOAD (with corresponding *AMPLITUDE curve). No mapping scheme needs to be specified for this conversion; the conversion is done automatically if present in the model.
All loads in a load collector with the LOAD card image assigned, are converted to respective loads, with scaling applied to loads as defined in the LOAD card.
Load Steps and Analysis Type
The conversion tool maps between Nastran subcases and Abaqus steps. It does not convert the solution types to/from any Abaqus analysis type. You must define them manually using the Abaqus Step Manager or the Load Step browser.
Systems and Mass
The conversion tool converts Nastran system types into the corresponding Abaqus system (*SYSTEM, *TRANSFORM or *ORIENTATION). It also converts the NSM into *NONSTRUCTURAL MASS and assigns them to the relevant properties. The mapping can be summarized as:
Nastran
Abaqus
NSM
*NONSTRUCTURAL MASS
NSM1
NSML
NSML1
NSMADD
GRID
*NODE and *SYSTEM
CORD1R
*SYSTEM for nodes
*TRANSFORM if referred to on GRID
*ORIENTATION for elements
CORD1C
CORD1S
CORD2R
CORD2C
CORD2S
WTMASS
If the WTMASS parameter is defined in the Nastran model, it is used to modify density, mass, and inertia values during conversion.
See Also:
Nastran Conversion Tools
