Engineering Solutions
Nastran to LS-DYNA Conversion
Use the Conversion tool to convert a Nastran file to a LS-DYNA file.
1.Load the Nastran user profile.
2.Import a Nastran model.
3.To run the conversion macro, from the menu bar, click Tools > Convert > Nastran >To LsDyna. The Conversion tab opens.
4.To start the conversion, click Convert. After the conversion, the selected version of the LS-DYNA user profile automatically loads.
5.Review and export the deck using the LS-DYNA user profile. Some of the keywords in the Nastran deck are converted to the LS-DYNA deck as per the following tables.
Element Mapping
Nastran type
LS-DYNA type
CONM2
*ELEMENT_MASS or *ELEMENT_INERTA
CWELD
Meshless weld
(feabsorb, fe realize using HEXA)
CDAMP1/CDAMP2
(0 length)
*ELEMENT_DISCRETE
(card edit for ground option check box)
PLOTEL
*ELEMENT_PLOTEL
RBAR/RBE2/RJOINT
*CONSTRAINED_NODAL_RIGID_BODY
RBE3
*CONSTRAINED_INTERPOLATION
CBAR/CBEAM/CROD/CTUBE/CBUSH
CELAS1/CELAS2
*ELEMENT_BEAM
CTRIA3/CTRIAR
CQUAD4, CQUADR, CSHEAR
CQUAD8, CTRIA6
(Change to 1st order then convert)
*ELEMENT_SHELL
CTETRA4/CHEXA8/CPENTA6
CTETRA10/CHEXA20/CPENTA15
*ELEMENT_SOLID
Property Mapping
Nastran type
LS-DYNA type
PBAR/PBEAM/PROD
(Only single section PBEAM is supported)
*SECTION_BEAM
PBARL/PBEAML/PRODL
(ROD, TUBE, BAR)
*SECTION_BEAM
PBUSH
*SECTION_BEAM + *MAT_GENERAL_SPRING_DISCRETE_BEAM
PELAS
*SECTION_BEAM + *MAT_1DOF_GENERALIZED_SPRING
PDAMP
*SECTION_DESCRETE
PSHELL/PSHEAR
*SECTION_SHELL
PSOLID
*SECTION_SOLID
PCOMP PCOMPG
*PART_COMPOSITE +*ELEMENT_SHELL with angle option; all materials referred in PCOMP, PCOMPG converted to *MAT_ORTHOTROPIC_THERMAL
Material Mapping
Nastran type
LS-DYNA type
MAT1
*MAT_ELASTIC
MAT2
*MAT_PIECEWISE_LINEAR _PLASTICITY
MAT4
MAT8
*MAT_ORTHOTROPIC_ELASTIC
MAT9
*MAT_ANISOTROPIC_ELASTIC
Coordinate System Mapping
Nastran type
LS-DYNA type
CORD1R
*DEFINE_COORDINATE_NODE
CORD2R
*DEFINE_COORDINATE_SYSTEM
Load Mapping
Nastran type
LS-DYNA type
SPC
*BOUNDARY_SPC
FORCE
*LOAD_NODE_POINT
MOMENT
*LOAD_NODE_POINT
PLOAD4
*LOAD_SEGMENT
TEMP
*INITIAL_TEMP
See Also:
Nastran Conversion Tools
