The network view is a block diagram view emphasizing inter-connectivity of the assembly. It is one of the three views in the assembly environment, along with the graphics view and the browser view. The network view is the best way to show coincident connections and provides an easy way for checking the number of connections between any two modules, reducing modeling errors.
To invoke the network view, click the icon.
Boxes represent modules or subsystems in an assembly. A typical module has a number of tagpoints represented by small circles on the border of the boxes. Ellipses represent connections between tagpoints on modules joined by two lines emanating from each ellipse. The arrow that appears on one end of the lines indicates that the module pointed to by the arrow is the owning module of the connection. |
When invoking the network view for the first time, an auto generated block diagram is displayed, which is not likely satisfying. After some effort in organizing the modules and connections, the block diagram can be organized in an easy to view form. The organized view can then be saved in the assembly .xml file so that the organized view will be available when the .xml file is imported. Recommended steps in organizing the network view
Module and connections can be selected to be moved by left-clicking the object. To move a tagpoint, left-click the small circle while holding down CTRL. When moving modules, attached connections can be set to either move with the modules by clicking the |
Double-clicking any module box or connection ellipse opens the module/connection manager to see the respective item’s definition. This option shows the ID range for modules. |
Modules can be created or deleted by using the right-click context menu. At this point, connection creation/deletion can only be done from the connection creation GUI and the Connector browser. The alignment of both module and connection can be accomplished from the same right-click context menu. |
Panning can be done by clicking CTRL and the middle mouse button, or by clicking the arrow in the toolbar. Dynamic zoom can be done by clicking CTRL and scrolling the middle mouse button. Window zoom can be done by clicking CTRL and drawing a window while holding the middle mouse button. Fixed zoom can be done using the icons shown below. Fit All can be done by clicking the |
Coloring capabilities assist you in quick diagnostic related to missing representations for a module, connection types and realization. A module with a solid red outline represents a module not assigned with a representation file A module with a solid black outline represents a module assigned with a representation file A module with a solid black outline and gray inside represents a module outside the subsystem selected for analysis A module with a solid black outline and green inside represents a module part of the rolled-up parent module and set for analysis A connection with a dotted blue outline and dark green inside represents a realized connection with PBUSH type A connection with a solid red outline and dark green inside represents a realized connection with Rigid type A connection with a solid black outline and red inside represents a failed connection for realization A connection with a solid black outline and gray inside represents a connection outside the subsystem selected for analysis and not selected for realization A connection with a solid black outline and light green inside represents a connection between the child modules of the rolled-up parent module and set for analysis Control Volume: Highlights the modules belonging to a particular control volume. Not in Analysis: Highlights the modules that are not defined for a particular analysis. |
Capability to export/import the network view using a template .csv file with the right-click context menu. |
