Engineering Solutions
Macros
Macros
Macros
This tool allows you to access pre-defined macros packaged with the NVH solution and also user-defined macros. To open it click Tools > NVH Macros from the menu bar when the NVH user profile is loaded.
Pre-defined macros are available in the Predefined tab.
nvh_macros_predefined
User-defined macros can be added/removed in the Userdefined tab.
nvh_macros_userdefined
Add and delete options are available in the right-click context menu. The selected macro fetches the design variables from the model property database and exports them to the FE input solver deck.
See Also:
Tools Menu
