The following features are available in the Tools menu:
Auto-Contact |
Quickly and easily create one or more contact interfaces at once between several parts of your model. This tool is only available in NVH when the OptiStruct and Nastran solvers are loaded. |
Create and modify a block entity. |
Select the entities that are viewed in the card image subpanel. |
Displays components and their associated attributes in an interactive table. |
Create Cards |
Displays a list of all available cards to create within the select user profile. |
Obtain a count of all the entities in your database. |
Delete data from a model database, preview and delete empty collectors and preview and delete unused property collectors, material collectors, or curves. |
Create or open a fatigue analysis setup process. |
Set of process templates that use generic engineering data to automatically create frequency response analysis loadcases and associated solver cards. |
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication. |
Review and edit OptiStruct load collectors. |
Create, manage and display loadsteps (sub-cases) and the associated control cards |
Review and edit OptiStruct materials |
Explore HyperMesh and HyperView data entities and export the entities to external files for further analysis. |
Model Checker |
Checks the model for errors and warnings. This tool is available in the Nastran and OptiStruct solvers in NVH. |
Access pre-defined macros packaged with the NVH solution and also user defined macros. |
Reorganize your database by copying or moving data (entities) among collectors or includes. |
Display/review and modify frequently used coordinate systems used in CAE analysis. |
Part Replacement |
Replace elements in an existing component/part (PSHELL) with new elements. |
Specify a new position for model entities. |
Create and edit 1D and 3D pretension bolt loads and bolt sections for the OptiStruct solver. This tool is only available when the OptiStruct user profile is loaded. |
Displays properties and their associated attributes in an interactive table. |
Quickly find and open the tools, panels and browsers that are available from the menu bar pull-downs or from the Utility browser. |
Reflect portions of a model about a plane, changing the selected portion into a mirror image of itself. |
Renumber entities. |
Rotate entities around an axis in space. |
Increase or decrease an entity’s dimensions. |
Automate the grouping and display of model components through the entity set functionality. |
Create, update and review named sets of entities. |
Run an external program from within Engineering Solutions or assign and run a solver on selected analysis decks. |
Obtain a summary of component element counts or element properties of the current model. |
Assign names to entities. |
Create, edit and move screen titles and entity tags. |
Translate, scale, reflect or rotate elements with multiple numbers of copies including properties and loads attached to them. |
Move entities in a single specified direction. |
