Engineering Solutions
Nastran
Nastran
Previous topic Next topic Expand/collapse all hidden text
Nastran
hmtoggle_plus1greyErrors
Name
Result
Auto correction action
Manual correction action
Material ID exceeds 8 characters
HyperMesh does not write out more than  eight characters for IDs, so if you have more HyperMesh will write out ***, which fails the solver. This check is disabled when using a long format template.
Lists the failing materials.
Not supported.
Opens the Renumber panel.
Property is missing material
Checks for properties without a material reference.
Lists the failing properties.
Not supported.
Opens the Properties panel.
Property ID exceeds 8 characters
Not supported.
Property with zero cross section area
Checks if the area of properties PBEAM, PBAR and PROD is less than or equal to zero.
Not supported.
Opens the Property panel.
Component with solids and shells
Checks if a component consists of both solid and shell elements.
Lists the failing components.
Not supported.
Opens the Organize panel.
Node ID exceeds 8 character
HyperMesh does not write out more than eight characters for ids, so if you have more HyperMesh will write out ***, which fails the solver.  This check is disabled when using a long format template.
Lists the failing nodes.
Not supported.
Element ID exceeds 8 characters
Lists the failing elements.
Not supported.
Free 1D elements
Checks for 1D elements that have one or more connection missing. This check does not include RBE2 or RBE3 elements.
Deletes the failing 1D elements.
Not supported.
RBE2 with constrained dependent nodes
Checks for RBE2 with constraints on dependent nodes.
Not supported.
Opens the Rigids panel.
Free Rigid elements
Checks for RBE2 elements that have one or more connection missing, typically a leg that is missing a connection.
Deletes the free arms of the Rigid.
Not supported.
Free RBE3 elements
Checks for RBE3 elements that have one or more connection missing, typically a leg that is missing a connection or an independent node that is not connected to structure.
Deletes the free arms of RBE3.
Not supported.
RBE3 elements are collinear
Checks if the dependent and independent nodes of an RBE3 element are collinear.
Deletes the failing RBE3 elements.
Not supported.
RBE3 dof connected to solid
Checks for rotational DOFs on independent nodes of an RBE3 connected to a solid element.
Removes rotational DOFs from affected independent grids of failing RBE3 elmements.
Not supported.
Zero-length CBUSH without CID
Checks if the CBUSH spring element of zero length has the element coordinate system, CID defined.
Not supported.
Opens the Springs panel.
Elements have a dependency
Checks for rigid elements that share dependent nodes with other rigid elements.
Deletes the failing rigid elements.
Not supported.
Element has rigid loops
Checks for rigid elements that form a closed loop; where the dependent node of one rigid serves as independent node of the next rigid in the loop.
Not supported.
Duplicate 1D Elements
Checks if any 1D elements share the same nodes in the same order.
Lists the duplicate 1D elements.
Deletes the failing elements.
Not supported.
Duplicate 2D Elements
Checks if any 2D elements share the same nodes in the same order.
Lists the duplicate 2D elements.
Not supported.
Duplicate 3D Elements
Checks if any 3D elements share the same nodes in the same order.
Lists the duplicate 3D elements.
Not supported.
NSM field not defined
Checks for invalid or missing entries on NSMADD loadcols.
Lists the failing loadcols.
Not supported.
Opens the Loadcols panel.
MPC with free independent nodes
Checks for MPC equations with free independent nodes.
Lists the failing equations.
Updates the MPC by removing the free independent node.
Not supported.
hmtoggle_plus1greyWarnings
Name
Result
Unused materials
Checks for any materials that are not referenced by a property.
Deletes unused materials.
Not supported.
Material E is not defined
Checks if E of MAT1 or MAT8 is less than or equal to zero.
Not supported.
Opens the Materials panel.
Material Rho is not defined
Checks if the Rho of MAT1, MAT2,MAT4 ,MAT5, MAT8, MAT9, MAT10,MATHE and MATHP is less than or equal to zero.
Not supported.
Material Nu is zero
Checks if the Nu of MAT1 and MAT8 is equal to zero.
Not supported.
Material is missing a card image
Checks for defined materials with no card image.
Not supported.
Unused properties
Checks for properties that are not assigned to a component or element.
Deletes unused properties.
Not supported.
Property is missing a card image
Checks for defined properties with no card image.
Not supported.
PSHELL thickness is not defined
Checks if the property PSHELL thickness is less than or equal to zero.
Not supported.
PSHELL and PSHLN1 with different MID
Checks if the property PSHELL has a different material defined for PSHELL and PSHLN1.
Not supported.
PCOMP thickness is not defined
Checks if the first thickness value of Property PCOMP array is less than or equal to zero. The first thickness value is mandatory.
Not supported.
1D Prop beamsection mismatch
Checks if the 1D property and the beam section attached to it have the same area and area moments of inertia. A difference greater than 0.01 will fail the check.
Disassociates the beam section from the 1D property.
Not supported.
Empty components
Checks for components that do not contain elements.
Deletes the empty components.
Not supported.
Empty assemblies
Checks if assemblies are empty.
Lists the empty assemblies.
Deletes empty assemblies.
Not supported.
Empty sets
Checks if sets are empty.
Lists empty sets.
Deletes empty sets.
Not supported.
Empty contact surfaces
Checks if contact surfaces are empty.
Lists empty contact surfaces.
Deletes empty contact surfaces.
Not supported.
Empty groups
Checks if groups are empty.
Lists empty groups.
Deletes empty groups.
Not supported.
Empty plys
Checks if plys are empty.
Lists empty plys.
Deletes empty plys.
Not supported.
Empty load collectors
Checks if load collectors are empty.
Lists empty load collectors.
Deletes empty load collectors.
Not supported.
Empty vector collectors
Checks if vector collectors are empty.
Lists empty vector collectors.
Deletes empty vector collectors.
Not supported.
Empty laminates
Checks if laminates are not having any ply.
Lists empty laminates.
Deletes empty laminates.
Not supported.
CONM1 with zero diagonal mass matrix values
Checks if the diagonal mass matrix values of CONM1 are less than or equal to zero.
Lists the failing CONM1.
Not supported.
Opens the Elements panel.
CONM2 with zero mass
Checks if the mass of CONM2 is less than or equal to zero.
Lists the failing CONM2.
Not supported.
Opens the Masses panel.
Orientation vector along axis vector
Checks if the orientation vector of bar elements CBEAM and CBAR is along axis vector.
Lists the failing bar elements.
Not supported.
Opens the Bars panel.
Element connectivity
Checks for shell elements connected by one or less nodes and solid elements connected by two or less nodes.
Not supported.
Unused BeamSections
Checks if any beamsections defined in the model are unused.
Lists the failing beamsections.
Deletes the unused beamsecions.
Not supported.
Unused sets
Checks if any sets are not used.
Lists unused sets.
Deletes unused sets.
Not supported.
Unused curves
Checks if any curves are not used.
Lists unused curves.
Deletes unused curves.
Not supported.
Unused systems
Checks if any systems in the model are not used.
Lists unused systems.
Deletes unused systems.
Not supported.
Unused laminates
Checks if any laminates in the model are not used.
Lists unused laminates.
Deletes unused laminates.
Not supported.
Unused plys
Checks if any plys in the model are not used.
Lists unused plys.
Deletes unused plys.
Not supported.
Unused vectors
Checks if any vectors in the model are not used.
Lists unused vectors.
Deletes unused vectors.
Not supported.
hmtoggle_plus1greyInfo
Name
Result
Components share the same property
Checks for two or more components that have the same property assigned.
Not supported.
Opens the Components panel.
Component does not have a property
Checks for components that contain elements but do not have any properties assigned.
Not supported.
