Engineering Solutions
RADIOSS
RADIOSS
Previous topic Next topic Expand/collapse all hidden text
RADIOSS
hmtoggle_plus1greyErrors
Name
Result
Auto correction action
Manual correction action
Id of material out of bounds
Checks if there are any material ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the materials with ids outside of the limit.
Not supported.
Opens the Renumber panel.
Nfunc must be greater than 0 for Law36
Checks if Law36 has a value defined for N_func.
Lists all materials of Law 36 which have N_func = 0.
Not supported.
Open the Entity Editor of the material entity.
Law36 has empty function definition
Checks if material Law36 has curves defined under NFUNC.
Lists all materials of law36 which have empty curve definitions.
Not supported.
Alpha greater than 1.0 for Law37
Checks if materials of Law37 have alpha1 values greater than 1.0.
Lists all materials of Law37 that have alpha1 values that are less than or equal to 1.0.
Not supported.
Id of property out of bounds
Checks if there are any property ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the properties with ids outside of the limit.
Not supported.
Id of group out of bounds
Checks if there are any group ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the groups with ids outside of the limit.
Not supported.
Master set not defined
Checks if there are any empty master sets in the interfaces.
List all interfaces that have an empty master.
Not supported.
Opens the Interface panel and updates the page.
Slave set not defined
Checks if there are any empty slave sets in the interface.
List all interfaces that have an empty slave.
Not supported.
Tied contacts: Slave nodes in master surface
Checks if the slave nodes of tied contacts are also present in its master.
Lists the tied contacts whose slave nodes are also present in its master.
Not supported.
Opens the Interface panel.
Id of node out of bounds
Checks if there are any node ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the nodes with ids outside of the limit.
Not supported.
Id of system out of bounds
Checks if there are any system ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the systems with ids outside of the limit.
Not supported.
Id of system collector out of bounds
Checks if there are any system collector ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the system collectors with ids outside of the limit.
Not supported.
Id of curve out of bounds
Checks if there are any curve ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the curves with ids outside of the limit.
Not supported.
Repeated X values in curve
Checks if abcissa values are clashing or repeated in a curve.
Lists all curves that have clashing or repeated absicca values, that is X values.
Not supported.
Opens the Curve editor to edit the curve fields.
Id of element out of bounds
Checks if there are any element ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the elements with ids outside of the limit.
Not supported.
Spring elements with zero length
Checks if spring elements have a length greater than zero.
Lists all spring elements with a null length.
Deletes all spring elements with a null length.
Not supported.
Pulley spring not defined with 3 nodes
Checks if a spring element that has a property of /PROP/SPR_PUL assigned is defined using three nodes.
Lists all spring elements that are not defined using exactly three nodes.
Deletes the element.
Not supported.
Joint nodes not on different rigids
Checks if a spring element that has a property of /PROP/KJOINT2 assigned to its component has node1 and node2 on different rigid elements.
Lists all spring elements whose node1 and node2 are on the same rigid elements.
Not supported.
All nodes not defined for universal joint
Checks if a spring element that has a property of /PROP/KJOINT2 assigned to its component and is of type 5 is defined using 4 nodes.
Lists all spring elements that are not defined using all four nodes.
Not supported.
Third node not defined for joint element
Checks if a spring that has a property of /PROP/KJOINT2 assigned to its component and is of type revolute, cylindrical, translation, or planar has a third node defined.
Lists all spring elements which are not defined using three nodes.
Not supported.
Common master of RBody, RLink, CylJoint
Checks if any rigid bodies (rigids, rigid links and cyl. joints) have common master nodes.
List all rigids that share common master nodes.
Splits the common master nodes.
Opens the corresponding Rigids panel and updates the page.
Common slave of RBody, RLink, CylJoint
Checks if any rigid bodies (rigids, rigid links and cyl. joints) have common slave nodes.
Lists all rigids that share common slave nodes.
Splits the common slave nodes.
0 slave nodes in Rbody
Checks if there are 0 slave nodes in Rbody.
Lists all Rbodies that have 0 slave nodes.
Not supported.
Rbody master is also slave
Checks if the master node of Rbody is also present in the slave side of the same Rbody.
Lists all Rbodies that have master node present in slave definition.
Not supported.
Ikrem value is incompatible with RWALL
Checks if the flag for rigidwall deactivation, Ikrem, is incompatible with RWALL. It is incompatible if the value of Ikrem is equal to one.
Lists all rigids that have Ikream incompatible to RWALL.
Sets Ikrem to 0.
Opens the corresponding RBODY card image.
Rbody master is in box that defines slave
Checks if Rbody master node is in the box defined by slave group of this RBODY.
Lists all bodies that have master node in the box defined by slave group of this RBODY.
Not supported.
Rbody master on element
Checks if the rbody master element is attached to a finite element.
Lists all of the rbodies whose master element is on a finite element.
Not supported.
Opens the Rigid panel.
Cascades of RBodies
Checks if the rbody master is also the slave of another rbody.
Lists all of the rbodies whose master is also a slave.
Not supported.
1D elements with duplicate nodes
Checks if 1D elements consists of two of the same nodes.
Lists all of the 1D elements with duplicate nodes.
Not supported.
Opens the Bars panel.
Duplicate 1D elements
Checks if two or more 1D elements are connected between the same nodes.
Lists all of the duplicate 1D elements.
Deletes the failing elements.
Not supported.
Duplicate 2D elements
Checks if two or more 2D elements are connected between the same nodes.
Lists all of the duplicate 2D elements.
Not supported.
Duplicate 3D elements
Checks if two or more 3D elements are connected between the same nodes.
Lists all of the duplicate 3D elements.
Not supported.
Degenerated 4 node Shells
Checks if four node shells have two of the same nodes within it.
Lists all of the 4 node shells with duplicate nodes.
Not supported.
Not supported.
Negative or zero volume of solids
Checks if a solid has zero or negative volume; Ideally when using HyperMesh you should not have negative volume.
Lists all of the solid elements with a zero or negative volume.
Deletes the failed solid elements.
Not supported.
Box definition with null length
Checks if there is a length defined for all three directions of a box, that is xmin!=xmax, and so on.
Lists all of the boxes with null lengths.
Not supported.
Opens the Entity Editor for the Block entity.
N1 and N2 are not defined on Box
Checks if N1 and N2 are defined on box/recta.
Lists all boxes of primitive type Rectangle that do not have N1 and N2 defined.
Not supported.
Opens the Entity Editor for the box entity.
Id of component out of bounds
Checks if there are any component ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the components with ids outside of the limit.
Not supported.
Component has more than one element type
Checks if a component has more than one unique element type (shell, solids, beam, discrete, and SPH).
Lists all components that have multiple element types.
Not supported.
Opens the Organize panel.
Component does not have a part card
Checks if any components are assigned the Part card image.
Lists all components that do not have a card image.
Not supported.
Opens the Entity Editor for the component entity.
Component missing property
Checks if the part component has a property attached.
Lists all of the components with no property attached.
Not supported.
Component missing material
Checks if the part component has a material attached.
Lists all of the components with no material attached.
Not supported.
Part, mat and prop incompatible
Checks if parts, properties, and materials are compatible according to the material compatibility table, and few other constraints mentioned in individual material and property definitions.
Lists all components whose elements are not compatible with the material and property attached or the attributed defined on them.
Not supported.
Id of Set out of bounds
Checks if there are any set ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the sets with ids outside of the limit.
Not supported.
Id of load out of bounds
Checks if there are any load ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the loads with ids outside of the limit.
Not supported.
Id of loadcols out of bounds
Checks if there are any load collector ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the load collectors with ids outside of the limit.
Not supported.
Initial velocity of type T+G.
Checks if initial velocity is of type T+G.
Lists all of the inivel load collectors of type T+G.
Not supported.
Opens the Entity Editor for the load collector entity.
Skew and frame defined in Impvel or Impdisp
Checks if /impvel and /impdisp have only one system associated with them.
Lists the /impvel and /impdisp with different systems present in skew and frame.
Not supported.
Isensor for Cload is not defined
Checks if Isensor is defined for Cload.
Lists all Cloads with Isensor not defined.
Not supported.
Opens the Entity Editor for the entity.
Grnod id for Cload is not defined
Checks if Grnod id is defined for Cload.
Lists all Cloads with Grnod ID not defined.
Not supported.
Skew for Cload is not defined
Checks if skew_csid is defined for Cload.
Lists all Cloads with skew_csid not defined.
Not supported.
Curve for Cload is not defined
Checks if fun_a1 is defined for Cload.
Lists all Cloads with fun_a1 not defined.
Not supported.
Id of beamsection out of bounds
Checks if there are any beam section ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the beam sections with ids outside of the limit.
Not supported.
Id of beamsection collector out of bounds
Checks if there are any beam section collector ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the beam section collectors with ids outside of the limit.
Not supported.
Id of parameters out of bounds
Checks if there are any parameter ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the parameters with ids outside of the limit.
Not supported.
ISkew cannot be a system of type Frame
Checks if the system attached to a sensor is of type Frame.
Lists all of the sensors that contain systems of type Frame.
Not supported.
Opens the Entity Editor for the sensor entity.
Id of output blocks out of bounds
Checks if there are any output block ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the output blocks with ids outside of the limit.
Not supported.
Id of contact surfaces out of bounds
Checks if there are any contact surface ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the contact surfaces with ids outside of the limit.
Not supported.
Id of control volumes out of bounds
Checks if there are any control volume ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the control volumes with ids outside of the limit.
Not supported.
Monitored volumes with empty surfaces
Checks if surfaces are defined on the airbag.
Lists all airbags that do not have surfaces defined on them.
Not supported.
Opens the Entity Editor for the control volume entity.
Monitored volumes with invalid vent holes data
Checks if area and surfs are defined on each vent of the airbag.
Lists all control volumes with zero area or no surface defined on any  vents.
Not supported.
Id of cross sections out of bounds
Checks if there are any cross section ids that are either less than the min_limit or more than the max_limit of allowable ids in the ID-Manager.
List all of the cross sections with ids outside of the limit.
Not supported.
Sections: N1, N2, N3 badly defined
Checks if the nodes of a cross section define a plane.
Lists all of the cross sections without a plane.
Not supported.
Opens the Entity Editor for the cross section entity.
hmtoggle_plus1greyWarnings
Name
Result
Unused materials
Checks if there any unused materials in the model.
Lists all unused materials.
Not supported.
Opens the material card image of  /MAT/PLAS_TAB.
Strain rate coefficient equal to 0 for LAW2
Checks if the strain rate coefficient is equal to zero for material LAW2.
Lists all of the law2 materials  that have a strain rate coefficient equal to zero.
Not supported.
Opens the material card image of either /MAT/PLAS_JOHNS or /MAT/PLAS_ZERIL.
Bad strain rate order in Law36
Checks for bad strain rate order in material Law36. The strain rate should be in increasing order
Lists all the law36 materials having bad strain rate order.
Not supported.
Material with zero density
Checks if material density is equal to zero.
Lists all of the materials that have zero density.
Not supported.
Opens the corresponding material card image.
Material with zero modulus
Checks if material modulus is equal to zero.
Lists all of the materials that have zero modulus.
Not supported.
Material with Poisson's Ratio less than 0.001
Checks if material Poisson’s Ratio is less than 0.001.
Lists all of the materials that have Poisson’s Ratio less than 0.001.
Not supported.
Law2,4,15,27: C and Eps0 defined but Fsmooth and Fcut blank
Checks for law2, 4, 15, 27: C and Epsdot0 are defined, and Fsmooth and Fcut are blank.
Lists all materials that failed the check.
Not supported.
Opens the Entity Editor of the material entity.
Law25 Tsai-Wu: C and Eps0 defined but Fsmooth and Fcut blank
Checks for law25, TSAI-WU: C12 and Epsdot0 are defined, and Fsmooth and Fcut are blank.
Not supported.
Law25 Crasurv: any C and E0 defined but Fsmooth, Fcut blank
Checks for law25, CRASURV: C (or any of c1t,c1c,c2t,c2c,c12t) and Epsdot0 are defined, and Fsmooth and Fcut are blank.
Not supported.
Law36,59,60: Nfunc > 0 but Fsmooth and Fcut blank
Checks for law36, 59, 60: Nfunct > 0, and Fsmooth and Fcut are blank.
Not supported.
Law44: C and p defined but Fsmooth and Fcut blank
Checks for law 44: C and p are defined, and Fsmooth and Fcut are blank.
Not supported.
Law48: C,K and E0 defined but Fcut blank
Checks for law48: C, K and Epsdot0 are defined, and Fcut is blank.
Not supported.
Law52: C and P defined but Fsmooth and Fcut blank
Checks for law52: C and p are defined, and Fsmooth and Fcut are blank.
Not supported.
Law65,77: Nrate or Nload > 1 but Fsmooth and Fcut blank
Checks for law65, 77: Nrate/Nload > 1, and Fsmooth and Fcut are blank.
Not supported.
Law70: Nload > 1 but lsmooth and Fcut blank
Checks for law 70: Nload > 1, and Fsmooth and Fcut are blank.
Not supported.
Law74: Eps rate scale defined but Fsmooth and Fcut blank
Checks for law74: Epsdot_scale is defined, and Fsmooth and Fcut are blank.
Not supported.
Law80: Ceps and Peps defined but Fsmooth and Fcut blank
Checks for law80: Ceps and Peps are defined, and Fsmooth and Fcut are blank.
Not supported.
Mat and referenced curves not in same include
Checks if a material and its referenced curves are in the same include.
Lists all of the materials that have curves that are not in same include file as the material.
Not supported.
Parameter and material title with &
Checks if a material name has "&" when a parameter is defined in the model.
Lists all materials whose name has "&" when a parameter is defined in the model.
Not supported.
Opens the Entity Editor of the entity.
Material with invalid name
Checks if a material name contains no more than 100 characters, and does not begin with a "/".
Lists all materials whose names are greater than 100 characters or begin with "/".
Not supported.
Unused properties
Checks if there are any unused properties in the model.
Lists all of the unused properties.
Deletes unused properties.
Not supported.
Section shell thickness
Checks if section shell thickness is less than or equal to zero.
Lists all of the shell properties that have a section thickness less than or equal to zero.
Not supported.
Opens the property card image of /PROP/SHELL.
Beam or truss property with area less than or equal to 0
Checks if beam and truss properties have an area equal to zero.
Lists all of the beam and truss properties that have an area less than or equal to zero.
Not supported.
Opens the corresponding truss or beam property card image.
Beam property with inertia less than or equal to 0
Checks if beam properties have an inertia less than or equal to zero.
Lists all of the beam properties that have inertia less than or equal to zero.
Not supported.
Opens the property card image of  /PROP/BEAM.
Spring property with inertia less than or equal to 0
Checks if spring properties have an inertia less than or equal to zero.
List all the spring properties that have an inertia less than or equal to zero.
Not supported.
Opens the property card image of  /PROP/SPRING.
Spring properties of type 4 or 8
Checks if spring properties are of type 4 and 8.
Lists all spring properties of type 4 and 8.
Not supported.
Opens the Entity Editor of the property entity.
Spring properties with null mass
Checks if spring properties have null mass.
Lists all of the spring properties that have null mass.
Not supported.
Invalid Icpre value on type 6
Checks if Icpre is defined for Isolid, not equal to 14, 17, and 24.
Lists all properties with icpre!=0 and isolid != 14,17,24.
Not supported.
Negative Gap value on type 2
Checks if GAP is negative on Type 2 properties.
Lists all properties of type 2 with a negative gap value.
Not supported.
Parameter and property title with &
Checks if a property name has "&" when a parameter is defined in the model.
Lists all properties whose name has "&" when a parameter is defined in the model.
Not supported.
Property with invalid name
Checks if a property name has no more than 100 characters and does not begin with a "/".
Lists all properties whose names are greater than 100 character, or begin with "/".
Not supported.
Prop and referenced entities not in same include
Checks if a property and its curve, sensor, or system are in the same include.
Lists all properties which reference entities that are not in the same include.
Not supported.
Istf is not equal to 0 or 1 for interface type 11
Checks if attribute Istf is not equal to zero or one for Inter type 11.
Lists all interfaces of type11 that have istf not equal to zero or one.
Not supported.
Opens the interface card image of  /INTER/TYPE11.
Idel is not equal to 1 for interface type 7
Checks if attribute Idel is not equal to one for interface type 7.
Lists all interfaces of type7 that have Idel not equal to one.
Not supported.
Opens the interface card image of  /INTER/TYPE7.
Bad Isearch flag interface in interface type 2
Checks if attribute Isearch is defined badly.
Lists all interfaces of type2 that have Isearch not equal to zero or two.
Not supported.
Opens the interface card image of  /INTER/TYPE2.
Bad spotflag in interface type2
Checks if Spotflag is badly defined for interface type 2.
Lists all interfaces of type2 that have a spotflag value not equal to zero.
Not supported.
Slave nodes in multiple interfaces
Checks if slave nodes are in multiple interfaces for TYPE2.
Lists all interfaces of type2 that have common slave nodes across multiple interfaces.
Not supported.
Un-Tied nodes in interface type 2
Checks if there are any free nodes in tied contacts, that is, contacts of type 2.
Lists all type2 contacts with free nodes.
Not supported.
Not supported.
Groups and referenced entities not in same include
Checks if group, master, slave, curves, and rbody are in the same include.
Lists all groups whose referenced entities are not in same include files as the group.
Not supported.
Opens the Entity Editor of the group entity.
Undefined master or slave in contact
Checks if groups contain undefined master or slave entities.
Lists all groups that reference undefined master or slave entities.
Not supported.
Unresolved master or slave in contact
Checks if a contact contains unresolved entities.
Lists all groups with unresolved master or slave entities.
Not supported.
Parameter and group title with &
Checks if a group name has "&" when a parameter is defined in the model.
Lists all groups whose names have "&" when a parameter is defined in the model.
Not supported.
Group with invalid name
Checks if a group name has no more than 100 characters and does not begin with a "/".
Lists all groups whose names are greater than 100 character or begin with "/".
Not supported.
Free nodes in the model
Checks if there are any free nodes in the model. Nodes present in EREF are also not considered free by the solver. As they represent the initial positions.
Lists all of the free nodes in the model.
Deletes free nodes.
Not supported.
Incompatible kinematic conditions on nodes
Checks if more than one type of imposed conditions is acting on nodes; for example if nodes are connected to more than one of the following - rigid elements, spotwelds, boundary conditions and tied contacts. Based on skew, attached boundary condition directions are checked if they are constrained in different dofs.
Lists all of the nodes that have more than one imposed condition.
Not supported.
Opens the Delete panel.
Systems with axis badly defined
Checks if the system axes are not defined correctly.
Lists all of the Systs with axis  that are badly defined.
Not supported.
Opens the Systs panel and updates the page.
Skew and nodes not in same include
Checks if a system and its nodes are in the same include.
Lists all of the systems that have nodes which are not in the same include.
Not supported.
Opens the Entity Editor of the system entity.
Parameter and system title with &
Checks if a system name has "&" when a parameter is defined in the model.
Lists all systems whose names have "&" when a parameter is defined in the model.
Not supported.
Systems with invalid name
Checks if a system name has no more than 100 characters and does not begin with a "/".
Lists all systems whose names are greater than 100 character or begin with "/".
Not supported.
Opens the Entity Editor of the entity.Opens the Entity Editor of the system entity.
Curve has no point
Checks if the function curve has any points defined.
Lists all of the function curves that do not have any points defined.
Creates a (0, 0) point.
Opens the Curves panel and updates the page.
Parameter and curve title with &
Checks if a curve name has "&" when a parameter is defined in the model.
Lists all curves whose names have "&" when a parameter is defined in the model.
Not supported.
Curve with invalid name
Checks if a curve name has no more than 100 characters and does not begin with a "/".
Lists all curves whose names are greater than 100 character or begin with "/".
Not supported.
1 slave node in Rbody
Checks if there is only one slave node in a Rbody.
Lists all of the Rbodies that have only 1 slave node.
Not supported.
Opens the Rigids panel and updates the page.
Admas and nodes not in same include
Checks if Admas and nodes are in the same include.
Lists all pf the admas that have nodes which are not in same include.
Not supported.
Opens the Entity Editor of the mass entity.
RBody and referenced entities not in same include
Checks if RBody, nodes, skew, sensor, and surf are in the same include.
Lists all of the rbodies that reference entities which are not in same include as the rbody.
Not supported.
Opens the Entity Editor of the Rbodies.
RLink and referenced entities not in same include
Checks if Rlink,  nodes, and skew are in the same include.
Lists all pf the rlinks that have nodes or skew which are not in same include.
Not supported.
Opens the Entity Editor of the Rlink.
Cyclic joint and nodes not in same include
Checks if a cyclic joint and its nodes are in the same include.
Lists all of the cyclic joints that have nodes which are not in same include.
Not supported.
Opens the Entity Editor of the cyclic joint.
Beam: 3 nodes aligned
Checks that the 3 nodes of a beam are non collinear.
Lists  beams with 3 nodes that are collinear.
Not supported.
Small rigid body with non-spherical inertia
Checks if  RBODY has non-spherical inertia.
Lists all small Rbodies that have non-spherical inertia.
Not supported.
Rbody ID is different from master ID
Checks if the Rbody ID is different from the master node ID.
Lists all Rbodies that have an ID different than the ID of the master node.
Not supported.
Spring elements length greater than 35
Checks if a spring with a property of /PROP/SPR_PUL assigned to its component has a length that is less than 35.
Lists all spring elements with a length greater than 35.
Delete the element.
Not supported.
Rigid body connected to only one part
Checks if rigid body slave nodes are connected to more than one component.
Lists all of the rigid bodies that are connected to only one part.
Not supported.
Rigid body has free slave nodes
Checks if all dependent nodes of rigid bodies are connected to some element.
Lists all RBODY that have at least one free dependent node.
Removes the free end nodes from the rigid body.
Not supported.
Free spring elements
Checks if there are free spring. elements
Lists all of the free spring elements.
Deletes free spring elements.
Not supported.
Free bar2 elements
Checks if there are free bar2 elements.
Lists all the free bar2 elements.
Deletes free bar2 elements.
Not supported.
Spring elems with null length
Checks if spring elements have a null length. Excludes those attached to properties of type 8.
Lists all spring elements that have a null length, other than those attached to properties of type 8.
Delete the spring elements.
Not supported.
Bar2 elems with null length
Checks of bar2 elements have a null length.
Lists all bar2 elements that have a null length.
Deletes the bar2 elements.
Not supported.
Mass elements have zero or negative mass
Checks if there are any mass elements that have zero or negative mass.
Lists all mass elements that have zero or negative mass.
Not supported.
Opens the Admas panel and updates the page.
Admas not compatible with 2D analysis
Checks if admas is present in the model, along with 2D analysis.
Lists all admas elements, if the 2D analysis flag is set.
Not supported.
Free mass elements
Checks if there are free mass elements.
Lists all of the free mass elements.
Deletes free mass elements.
Not supported.
Joint nodes are non-coincident
Checks if a spring element that has a property of /PROP/KJOINT2 assigned to its component has a node1 and node2 that are coincident.
Lists all spring elements with non-coincident node 1 and node 2.
Deletes the elements.
Not supported.
3-4 Node shells with thickness
Checks if 3 or 4 noded shell elements have a thickness defined on the element itself.
Lists all 3 or 4 noded shell elements with a thickness.
Not supported.
Xalea of Random noise less than or equal to zero
Checks for random noise. You will have a random noise issue if the attribute XALEA of RANDOM control card is not equal to or less than zero.
Lists all the RANDOM control cards that have an attribute XALEA not equal to or less than zero.
Not supported.
Opens the card image of control card /RANDOM.
Unused boxes
Checks if there are unused boxes in the model.
Lists all unused boxes.
Deletes unused boxes.
Not supported.
Parameter and box title with &
Checks if a box name has "&" when a parameter is defined in the model.
Lists all boxes whose names have "&" when a parameter is defined in the model.
Not supported.
Boxes with invalid name
Checks if a box name has no more than 100 characters and does not begin with a "/".
Lists all boxes whose names are greater than 100 character or begin with "/".
Not supported.
Component is referring to undefined entity
Checks if components reference undefined properties or materials.
Lists all components containing undefined materials or properties.
Not supported.
Component is referring to unresolved entity
Checks if components reference unresolved properties or materials.
Lists all components containing unresolved materials or properties.
Not supported.
Hourglass possible on component
Checks if hourglass is possible on a component; if the attached property has ishell = 1,2 or 3 or isolid = 1 or 2.
Lists all components with property attributes as mentioned earlier.
Not supported.
Parameter and component title with &
Checks if a component name has "&" when a parameter is defined in the model.
Lists all components whose names have "&" when a parameter is defined in the model.
Not supported.
Comps with invalid name
Checks if a component name has no more than 100 characters and does not begin with a "/".
Lists all components whose names are greater than 100 character or begin with "/".
Not supported.
Part and referenced entities not in same include
Checks if a part and its associated entities are in the same include file.
Lists all parts which reference entities that are not in the same include file.
Not supported.
Unused sets
Checks if a set is not referenced by another entity.
Lists all sets which are unused.
Deletes unused sets.
Not supported.
Empty sets
Checks if a set has entity ids.
Lists all sets which do not contain any entities.
Deletes empty sets.
Not supported.
Sets with no finite elements or nodes
Checks if the defined set contains valid finite elements/nodes. This check does not report sets already reported under "empty sets".
Lists all sets which have empty components, sets, and so on attached to them.
Not supported.
Grspri with inconsistent element
Checks if Grspri contains only spring elements.
Lists all Grspri that contain more than spring elements.
Not supported.
Not supported.
Grbeam with inconsistent element
Checks if Grbream contains only beam elements.
Lists all Grbream that contain more than spring elements.
Not supported.
Not supported.
Grshel with inconsistent element
Checks if Grshel contains only 4 noded elements.
Lists all Grshel that contain more than 4 noded shell elements.
Not supported.
Not supported.
Grsh3n with inconsistent element
Checks if Grsh3n contains only 3 noded shell elements.
Lists all Grsh3n that contain more than 3 noded shell elements.
Not supported.
Not supported.
Grtruss with inconsistent element
Checks if Grtruss contains only truss elements.
Lists all Grtruss that contain more than truss elements.
Not supported.
Not supported.
Grquad with inconsistent element
Checks if Grquad contains only quad elements.
Lists all Grquad that contain more than quad elements.
Not supported.
Not supported.
Grbric with inconsistent element
Checks if Grbric contains only brick elements.
Lists all Grbric that contain more than brick elements.
Not supported.
Not supported.
Entity set refers to undefined entity
Checks if sets contain undefined entities.
Lists all sets that reference undefined entities.
Not supported.
Entity set is referring to unresolved entity
Checks if a set contains unresolved entities.
Lists all sets which refer to unresolved entities.
Removes unresolved entities from the set.
Not supported.
Parameter and set title with &
Checks if a set name has "&" when a parameter is defined in the model.
Lists all sets whose names have "&" when a parameter is defined in the model.
Not supported.
Sets with invalid name
Checks if a set name is no more than 100 characters and does not begin with "/".
Lists all sets whose names are greater than 100 characters or begin with "/".
Not supported.
Grbeam and referenced entity not in same include
Checks if a Grbeam and its associated entities are in the same Include file.
Lists all Grbeams which reference entities that are not in the same Include file.
Not supported.
Grbric and referenced entity not in same include
Checks if a Grbric and its associated entities are in the same Include file.
Lists all Grbrics which reference entities that are not in the same Include file.
Not supported.
Grnod and referenced entity not in same include
Checks if a Grnod and its associated entities are in the same Include file.
Lists all Grnods which reference entities that are not in the same Include file.
Not supported.
Grpart and referenced entity not in same include
Checks if a Grpart and its associated entities are in the same Include file.
Lists all Grparts which reference entities that are not in the same Include file.
Not supported.
Grquad and referenced entity not in same include
Checks if a Grquad and its associated entities are in the same Include file.
Lists all Grquads which reference entities that are not in the same Include file.
Not supported.
Grsh3n and referenced entity not in same include
Checks if a Grsh3n and its associated entities are in the same Include file.
Lists all Grsh3ns which reference entities that are not in the same Include file.
Not supported.
Grshel and referenced entity not in same include
Checks if a Grshel and its associated entities are in the same Include file.
Lists all Grshels which reference entities that are not in the same Include file.
Not supported.
Grspri and referenced entity not in same include
Checks if a Grspri and its associated entities are in the same Include file.
Lists all Grspris which reference entities that are not in the same Include file.
Not supported.
Grtruss and referenced entity not in same include
Checks if a Grtruss and its associated entities are in the same Include file.
Lists all Grtrusses which reference entities that are not in the same Include file.
Not supported.
Surf and referenced entity not in same include
Checks if a Surf and its associated entities are in the same Include file.
Lists all Surfs which reference entities that are not in the same Include file.
Not supported.
Bcs, grnod, skew not in same include
Checks if Bcs, Grnod, and skew are in same include.
Lists all bcs that have nodes or skew which are not in same include.
Not supported.
Opens the Entity Editor of the load collector entity.
Inivel, grnod and skew not in same include
Checks if Inivel, Grnod and skew are in same include.
Lists all inivel whose nodes or skew are not in same include.
Not supported.
Impvel, and referenced entities not in same include
Checks if impvel, grnod, sensor, skew and curves are in the same include.
Lists all impvel with nodes, sensor, skew, or curves that are not in same include as itself.
Not supported.
Impdisp, and referenced entities not in same include
Checks if impdisp, grnod, sensor, skew, and curves are in the same include.
Lists all impdisp with nodes, sensor, skew, or curves that are not in same include as itself.
Not supported.
Pload, referenced entities not in same include
Checks if Pload, Surf, sensor, Skew, and Curves are in the same include.
Lists all pload with surfs, sensor, contact surfs, skew, or curves that are not in same include as itself.
Not supported.
Grav, and referenced entities not in same include
Checks if Grav, Grnod, sensor, Skew, and curves are in the same include.
Lists all grav with nodes, sensor, skew, or curves that are not in same include as itself.
Not supported.
Parameter and loadcol title with &
Checks if a load collector name has "&" when a parameter is defined in the model.
Lists all load collectors whose names have "&" when a parameter is defined in the model.
Not supported.
Detpoint and referenced entities not in same include
Checks if a Detpoint and its associated entities are in the same Include file.
Lists all Detpoints which reference entities that are not in the same Include file.
Not supported.
Activ and references entities not in same include
Checks if an Activ and its associated entities are in the same Include file.
Lists all Activs which reference entities that are not in the same Include file.
Not supported.
Unresolved ids in Activ
Checks if an Activ contains unresolved entities.
Lists all Activs which reference entities that are unresolved.
Not supported.
Cload and referenced entities not in same include
Checks if a Cload and its associated entities are in the same Include file.
Lists all Cloads which reference entities that are not in the same Include file.
Not supported.
Convec and referenced entities not in same include
Checks if a Convec and its associated entities are in the same Include file.
Lists all Convec which reference entities that are not in the same Include file.
Not supported.
Impacc and referenced entities not in same include
Checks if an Impacc and its associated entities are in the same Include file.
Lists all Impaccs which reference entities that are not in the same Include file.
Not supported.
Imptemp and referenced entities not in same include
Checks if an Imptemp and its associated entities are in the same Include file.
Lists all Imptemps which reference entities that are not in the same Include file.
Not supported.
Pfluid and referenced entities not in same include
Checks if a Pfluid and its associated entities are in the same Include file.
Lists all Pfluids which reference entities that are not in the same Include file.
Not supported.
Radiation and referenced entities not in same include
Checks if a Radiation and its associated entities are in the same Include file.
Lists all Radiations which reference entities that are not in the same Include file.
Not supported.
Detline and referenced entities not in same include
Checks if a Detline and its associated entities are in the same Include file.
Lists all Detlines which reference entities that are not in the same Include file.
Not supported.
Waveshapers and referenced entities not in same include
Checks if a Waveshaper and its associated entities are in the same Include file.
Lists all Waveshapers which reference entities that are not in the same Include file.
Not supported.
Laser and referenced entities not in same include
Checks if a Laser and its associated entities are in the same Include file.
Lists all Lasers which reference entities that are not in the same Include file.
Not supported.
Inout and referenced entities not in same include
Checks if an Inout and its associated entities are in the same Include file.
Lists all Inouts which reference entities that are not in the same Include file.
Not supported.
Loadcols with Invalid name
Checks if a load collector name is not more than 100 characters and does not begin with a "/".
Lists all load collectors whose names are greater than 100 characters or begin with "/".
Not supported.
Unused BeamSections
Checks if any beamsection defined in the model is unused.
Lists all of the unused beamsections in the model.
Deletes the unused beamsections.
Not supported.
Unused parameters
Checks if there are any unused parameters in the model.
Lists all parameters that are unused/not referenced in another entity.
Deletes unused parameters.
Not supported.
Parameter definition in include file
Checks if parameters are present in include files. If yes, then give a warning. PARAMETER/LOCAL is currently not supported,  hence the check.
Lists all parameters that are defined in the include file.
Not supported.
Opens the Entity Editor of the parameter entity.
Fcut is greater than or equal to 0 for Accel
Checks if Fcut is greater than zero on an Accel card.
Lists all Accels with Fcut less than or equal to zero.
Not supported.
More than one Accel on the same node
Checks if more than one Accel is acting on the node.
Lists all Accels repeated on the node.
Not supported.
Accel and referenced entities not in same include
Checks if an Accel and its referenced entities are in the same Include file.
Lists all Accels which reference entities that are not in the same Include file.
Not supported.
Node id and skew id for accel card are unresolved
checks if node_id and skew_id are unresolved for the accel card.
Lists all Accels with an unresolved node_id or skew_id.
Not supported.
Nodes with same skew in different TH
Checks if the same node with the same system is referenced in more than one TH.
Lists all output blocks that contain a node that is repeated with the same system.
Not supported.
TH with repeated entities
Checks if entities are repeated within each TH.
Lists all output blocks that contain repeated node IDs.
Not supported.
Parameter and output block title with &
Checks if an output block name has "&" when a parameter is defined in the model.
Lists all output blocks whose names have "&" when a parameter is defined in the model.
Not supported.
Output blocks with invalid name
Check if an output block name is no more than 100 characters and does not begin with "/".
Lists all output blocks whose names are greater than 100 characters or begin with "/".
Not supported.
Th and referenced entities not in same include
Checks if Th and its associated entities are in the same Include file.
Lists all Th which reference entities that are not in the same Include file.
Not supported.
Parameter and contact surf title with &
Checks if a contact surface name has "&" when a parameter is defined in the model.
Lists all contact surfaces whose names have "&" when a parameter is defined in the model.
Not supported.
Contact surfs with invalid name
Checks if a contact surface name is not more than 100 characters and does not begin with "/".
Lists all contact surfaces with names greater than 100 characters or begins with "/".
Not supported.
Monvol, surfs, sensors, curves not in same include
Checks if a control volume and its associated surface, sensor, or curve are in the same Include file.
Lists all control volumes which reference entities that are not in the same Include file.
Not supported.
Control vols with invalid name
Checks if a control volume name is not more than 100 characters and does not begin with "/".
Lists all control volumes with names greater than 100 characters or begin with "/".
Not supported.
Parameter and control vol title with &
Checks if a control volume name has "&" when a parameter is defined in the model.
Lists all control volumes whose names have "&" when a parameter is defined in the model.
Not supported.
Incompatible material
Checks if materials and properties are compatible with xref and refsta.
Lists all xref/refsta with incompatible materials or properties.
Not supported.
Eref incompatible material
Checks if materials and properties are compatible with Eref.
Lists all Eref with incompatible materials or properties.
Not supported.
XRef or Refsta, and nodes not in same include
Checks if Xref/Refsta and its nodes are in the same include.
Lists all impdisp with nodes, skew, or curves that are not in the same include as itself.
Not supported.
Opens the Entity Editor of the control volume entity.
Airbag1 and referenced entities not in same include
Checks if an Airbag1 and its associated entities are in the same Include file.
Lists all Airbag1s which reference entities that are not in the same Include file.
Not supported.
Area and referenced entities not in same include
Checks if an Area and its associated entities are in the same Include file.
Lists all Areas which reference entities that are not in the same Include file.
Not supported.
Commu1 and referenced entities not in same include
Checks if a Commu1 and its associated entities are in the same Include file.
Lists all Commu1s which reference entities that are not in the same Include file.
Not supported.
Fvmbag1 and referenced entities not in same include
Checks if a Fvmbag1 and its associated entities are in the same Include file.
Lists all Fvmbag1s which reference entities that are not in the same Include file.
Not supported.
Pres and referenced entities not in same include
Checks if a Pres and its associated entities are in the same Include file.
Lists all Pres which reference entities that are not in the same Include file.
Not supported.
Perfect gas and referenced entities not in same include
Checks if an Perfect gas and its associated entities are in the same Include file.
Lists all Perfect gases which reference entities that are not in the same Include file.
Not supported.
Airbag and referenced entities not in same include
Checks if an Airbag and its associated entities are in the same Include file.
Lists all Airbags which reference entities that are not in the same Include file.
Not supported.
Commu and referenced entities not in same include
Checks if a Commu and its associated entities are in the same Include file.
Lists all Commus which reference entities that are not in the same Include file.
Not supported.
Fvmbag and referenced entities not in same include
Checks if a Fvmbag and its associated entities are in the same Include file.
Lists all Fvmbags which reference entities that are not in the same Include file.
Not supported.
Sections, N1, N2, N3 not in same include
Checks if a Cross Section and its associated nodes are in the same Include file.
Lists all Cross sections which reference nodes that are not in the same Include file.
Not supported.
Sections, sets and frames not in same include
Checks if a Cross section and its associated sets and frames are in the same Include file.
Lists all Cross sections which reference sets and frames that are not in the same Include file.
Not supported.
Parameter and cross section title with &
Checks if a cross section name has "&" when a parameter is defined in the model.
Lists all cross sections whose names have "&" when a parameter is defined in the model.
Not supported.
Cross sections with invalid name
Checks if a cross section name has no more than 100 characters and does begin with "/".
Lists all cross sections whose names are greater than 100 characters or begin with "/".
Not supported.
hmtoggle_plus1greyInfo
Name
Result
Number of defined materials
Checks for the number of defined material entities in the model.
Lists all of the defined materials.
Not supported.
Not supported.
Number of undefined materials
Checks for the number of undefined material entities in the model.
Lists all of the undefined materials.
Not supported.
Not supported.
Number of defined properties
Checks for the number of defined property entities in the model.
Lists all of the defined properties.
Not supported.
Not supported.
Number of undefined properties
Checks for the number of undefined property entities in the model.
Lists all of the undefined properties.
Not supported.
Not supported.
Number of groups
Checks for the number of group entities in the model.
Lists all group entities.
Not supported.
Not supported.
Nodes not connected to elements
Checks if there are any nodes that are not connected to elements.
Lists all of the nodes in the model that are not connected to elements.
Not supported.
Not supported.
Number of defined curves
Checks for the number of defined curve entities in the model.
Lists all of the defined curves.
Not supported.
Not supported.
Number of undefined curves
Checks for the number of undefined curve entities in the model.
Lists all of the undefined curves.
Not supported.
Not supported.
Number of defined sets
Checks for the number of defined set entities in the model.
Lists all of the defined sets.
Not supported.
Not supported.
Number of undefined sets
Checks for the number  undefined set entities in the model.
Lists all of the undefined sets.
Not supported.
Not supported.
Number of output blocks
Checks for the number of output blocks in the model.
Lists all of the output blocks.
Not supported.
Not supported.
