Engineering Solutions
Model Checker
Model Checker
Previous topic Next topic Expand/collapse all hidden text
Model Checker
Model Checker is invoked by clicking Tools > Model Checker. There are two levels of checks available:
Model Checker – Elements checks the quality of the elements.
Model Checker – Solver checks the models for errors and warnings. The following solvers are supported: LS-DYNA, OptiStruct, RADIOSS, Nastran, Abaqus and ANSYS.
Upon invoking the Model Checker – Solver, a browser tab appears.
The following folders are available:
Error
This folder contains the list of checks performed. The solver will not run if there are errors.
Warning
This folder contains the list of checks performed, which are either warnings from the solver or general warnings. The solver will still run with these warnings.
Info
There is more for information on the content of the model.
model_checker_lsdyna
hmtoggle_plus1greyToolbars
The Model Checker includes toolbars and a context menu. Toolbars provide the ability to switch between views and provides other options.
Icon
Function
tabCheckReviewFlat-24
The browser shows the contents in three folders: Error, Warning and Info.
tabCheckRunFlat-24
The browser shows the contents in terms of HyperMesh entities.
fixAuto-24
Apply Auto Correction globally.
run-24
Run the Model Checker.
hmtoggle_plus1greyRunning Model Checker
In the Model Checker tab, you can select the list of checks to be performed before running the Model Checker. Selections can be made using the SHIFT and CTRL keys for multiple selections. If nothing is selected and the Model Checker is run, then all checks are performed.
The Model Checker context menu provides options to show, hide and isolate, cross reference entities, apply auto correction (if an auto correction is applicable for the selected error), apply manual corrections and card edit.
hmtoggle_plus1greyStatus of the Results
If the Model Checker tab is open and any changes are made in the model, then Model Checker is automatically rerun. The checks that are rerun are determined by the entity that is affected. For example, if a material card is edited all checks related to material are rerun.
Note:For large models, checking the model could take some time. It is recommended that if other major operations are being performed in the model (other than fixing errors using the right-click context menu of auto correction or manual correction), to close the Model Checker tab and perform those operations first. Then, rerun the Model Checker if needed. For example, importing a model while the Model Checker browser is open can delay the operations.
Checks that are related to attribute values works on explicitly defined values. If no value is defined (field is blank) then the Model Checker will not interpret this as zero.
hmtoggle_plus1greyConfiguring the Model Checker
There is a default config file used for checking the model. You can make changes to the config file and run customized checks. A description of the config file and checks and corrections can be found in the HyperMesh Reference Guide.
