Engineering Solutions
ANSYS
ANSYS
Previous topic Next topic Expand/collapse all hidden text
ANSYS
hmtoggle_plus1greyErrors
Name
Result
Auto correction action
Manual correction action
Remarks
Component without HM_COMP
Checks and flags components that do not have a HM_COMP card image.
Lists the components that failed the check.
Supported.
Not Supported.
The HM_COMP card image should be attached to all components except those that have only RBE3 and RIGID.
Component without ET TYPE
Checks and flags components that have a card image, but do not have a sensor attached.
Not Supported.
Opens the Card Image panel.
ET Type and Element config mismatch
Checks and flags components whose ET Type does not match with any of the element types in the component.
Not Supported.
ET Type and Real sets or Sections are not matching
Checks and flags components that have a property type that does not match the ET Type. Targe169 and targ170 components can have a property type of any of the related contact types.
Checks and flags components that have an ET Type and section that do not match.
Not Supported.
Opens the Components panel.
The GENERALp property can be attached to componenets that have any ET Type.
Unpaired contacts
Checks and flags components of contact elements which are single. Components are identified based on the property attached to them.
Not Supported.
Not Supported.
Mass elements without property
Checks and flags MASS21 and/or MASS71 elements if they have no property attached or if the attached property is not of type MASS21p or MASS71p, and if the values related to the mass elements are zero.
Lists the elements that failed the check.
Not Supported.
Not Supported.
It is necessary to define at least one of the mass values on the property.
Improper Entity Set Names
Checks and flags entity sets with a name that is longer than 32 characters, contains special characters other than an underscore, or that does not start with a letter in the alphabet.
Lists the entity sets that failed the check.
Renames the set by removing the special characters, reducing the length of the name to 32 characters, and/or removing the non alphabetic characters from the start of the name.
Not Supported.
Hypen and space are also considered special characters. The Model Checker currently does not check to see if the name already exists.
Free Nodes
Checks and flags nodes that are not connected to a valid ANSYS element.
Lists the nodes that failed the check.
Deletes the free nodes.
Not Supported.
RBE3, CERIG, and CP are considered equations by ANSYS.
Free 1D elements
Checks and flags 1D elements that are not attached to any structural components.
Deletes the free 1D elements.
Not Supported.
Duplicate 1D Elements
Checks and flags 1D elements that are connected between the same two nodes.
Deletes the duplicate 1D elements.
Not Supported.
The order of nodes does not matter.
Duplicate 2D Elements
Checks and flags 2D elements that share common nodes.
Deletes the duplicate 2D elements.
Not Supported.
Duplicate 3D Elements
Checks and flags 3D elements that share common nodes.
Deletes the duplicate 3D elements.
Not Supported.
Pretension elements without third node
Checks and flags pretension elements that do not have a direction node.
Not Supported.
Not Supported.
RBE3, CERIG and CP with free nodes
Checks and flags the RBE3, CERIG, and CPs with free, independent and dependent nodes.
Lists the RBE3, CERIG and CPs that failed the check.
Not Supported.
Not Supported.
The nodes need to be connected to a valid ANSYS element.
Equation with free nodes
Checks and flags equations that have nodes which are not connected to elements. RBE3 and RIGIDS are considered equations in ANSYS.
Lists the equations that failed the check.
Not Supported.
Not Supported.
Invalid pilot node sets
Checks for pilot node sets that have more than one node.
Lists all pilot node sets that have more than one node.
Not Supported.
Opens the Entity Edit: Sets dialog.
Invalid contact surfaces
Checks for contact surfaces that have mixed surfaces.
Cases of mixed surfaces includes:
Any shell edge + any solid face
First order shell edge + second order shell edge
First order solid face + second order solid face
Lists all contact surfaces that have mixed surfaces.
Not Supported.
Opens the Entity Edit: Contactsurfs dialog.
Incomplete contact pairs
Checks for contact groups that have one or more of the following conditions:
Missing both contact and target surface attachments.
Missing a contact or target surface.
Missing an ET Type for either a contact or target surface.
No property card is assigned.
Lists all contact groups that fail the check.
Not Supported.
Opens the Entity Edit: Groups dialog.
Invalid contact pairs
Checks for contact pairs that have the following:
1.There is a mismatch of Et Type (sensor) and contact/target surfaces, and the correct match of the sensor and contact/target surface are in the given below.
2.The Contact sensor type and property type in the contact pair are different.
3.The contact is a solid face, and the target is a shell edge or vice versa.
Lists all contact pairs that fail the check.
Not Supported.
hmtoggle_plus1greyWarnings
Name
Result
Remarks
Unused ET Types
Checks and flags the ET Types that are not referenced by any components.
Lists the ET Types that failed the check.
Deletes the unused ET Types.
Not Supported.
Unused materials
Checks and flags the materials that are not referenced by any of the entities in the model.
Lists the materials that failed the check.
Deletes the unused materials.
Not Supported.
Material without E
Checks and flags materials if EX_FLAG, EY_FLAG, or EZ_FLAG is not activated, and if at least one of the array values is non zero.
Not Supported.
Material without density
Checks and flags materials if DENS_FLAG is not activated, or if any of the array values are not assigned.
Not Supported.
Unused Real Sets (properties)
Checks and flags the properties that are not referenced by any of the entities in the model.
Lists the properties that failed the check.
Deletes the unused properties.
Not Supported.
Shell properties or sections without thickness
Checks and flags properties that have the first thickness as zero. If it is a composite property, then the first thickness on each ply should be greater than zero.
Checks and flags shell sections that do not have a thickness assigned on any of the plies.
Lists the properties and beam sections that failed the check.
Not Supported.
Mass properties without mass
Checks for properties with a mass card image, but no mass.
Lists all properties with a mass card image, but no mass.
Not Supported.
Empty components
Checks and flags the empty components.
Deletes the unused components.
Not Supported.
Component with missing material
Checks and flags the components that do not have a material attached. This is checked irrespective of whether there is a sensor attached to it or not.
Not Supported.
Empty sets
Checks and flags empty sets in the model.
Lists the sets that failed the check.
Deletes the unused sets.
Not Supported.
Bar Elements with improper orientation
Checks and flags bar elements with an orientation vector that is not perpendicular to the z axes.
Not Supported.
Not Supported.
Bar elements in ANSYS are created so that the beam's y-axes is parallel to the global XY-axes.
Unused Sections
Checks and flags sections (beamsectcols) that are not referenced by any components.
Lists the beamsectcols that failed the check.
Deletes the unused beamsectcols.
Not Supported.
Unused Contact surfaces
Checks for contact surfaces that are not used in a contact pair.
Lists all contact surfaces that are not used in a contact pair.
Deletes unused contact surfaces.
Opens the Interfaces panel.
Unused Contact masses
Checks for contact mass node sets that are not used in a contact pair.
Lists all contact mass node sets that are not used in a contact pair.
Deletes unused contact masses.
Unused Pilot nodes
Checks for pilot node sets that are not used.
Lists all pilot node sets that are not used.
Deletes unused pilot nodes.
hmtoggle_plus1greyInfo
Name
Result
Components without property or section
Checks and flags components that have an ET Type attached which require, but do not have, a property or section.
Not Supported.
Not Supported.
SOLVE without /solu card
Checks and flags SOLVE cards to see if it is activated without the /solu card.
Lists the SOLVE control card that failed the check.
Not Supported.
Not Supported.
LSSOLVE without /solu card
Checks and flags the LSSOLVE card to see if it is activated without the /solu card.
Lists the LSSOLVE control card that failed the check.
Not Supported.
Not Supported.
Properties without card image
Checks for properties that do not have a card image attached.
Lists all properties that do not have a card image attached.
Not Supported.
Not Supported.
Empty Contact Surfaces
Checks for contact surfaces that do not contain a single element surface.
Lists all contact surfaces that do not contain a single element surface.
Not Supported.
Not Supported.
Empty Contact Masses
Checks for node sets that have a contact mass card image, but do not contain nodes.
Lists all node sets that have a contact mass card image, but do not contain nodes.
Not Supported.
Not Supported.
Empty PilotNode Set
Checks for node sets that have a pilot node card image, but do not contain nodes.
Lists all node sets that have a pilot node card image, but do not contain nodes.
Not Supported.
Not Supported.
