Engineering Solutions
Abaqus
Abaqus
Previous topic Next topic Expand/collapse all hidden text
Abaqus
hmtoggle_plus1greyErrors
Name
Result
Auto correction action
Manual correction action
Property card has NO material card
Checks for properties that are assigned to components or elements, but without a material reference.
Lists all properties that have no materials defined.
Not Supported.
Opens the Properties panel.
Common nodes of RBodies
Checks if the rigid entities have common nodes.
Lists all of the rigid entities with common nodes.
Not Supported.
Opens the Rigid Link Creation panel.
Duplicate 1D Elements
Checks if any 1D elements share the same nodes in the same order.
Lists the duplicate 1D elements.
Deletes the failing elements.
Not Supported.
Duplicate 2D Elements
Checks if any 2D elements share the same nodes in the same order.
Lists the duplicate 2D elements.
Not Supported.
Duplicate 3D Elements
Checks if any 3D elements share the same nodes in the same order.
Lists the duplicate 3D elements.
Not Supported.
Component with solid and shells
Checks if a component consists of both solid and shell elements.
Lists the failing components.
Not Supported.
Opens the Organize panel.
hmtoggle_plus1greyWarnings
Name
Result
Negative density
Checks if any materials have negative density defined.
Lists all of the materials that have negative density.
Not supported.
Opens the Card Image panel.
Negative Young's Modulus
Checks if any materials have negative Young's Modulus defined.
Lists all materials that have negative Young's Modulus.
Not supported.
Negative Poisson Ratio
Checks if any materials have negative Poisson Ratio defined.
Lists all materials that have negative Poisson Ratio.
Not supported.
Poisson Ratio greater than 0.5
Checks if the Poisson Ratio value for any material is greater than 0.5.
Lists all materials that have Poisson Ratio greater than 0.5.
Not supported.
Unused materials
Checks for any materials that are not referenced by a property.
Lists the unused materials.
Deletes the unused materials.
Not supported.
Material Elasticity is not defined
Checks if Elasticity is defined for the material. This check is applicable for only Isotropic Elastic Material.
Lists materials with no Young's Modulus value.
Not Supported.
Opens the Materials panel.
Material density is not defined
Checks if density is defined for the material.
Lists materials with no density value.
Not Supported.
Material Piosson Ratio is not defined
Checks if Piosson Ratio is defined for the material.
Lists materials with no Piosson Ratio value.
Not Supported.
Material is missing a card image
Checks if the card image is selected for material.
Lists materials with no card image.
Not supported.
Unused properties
Checks for properties not used in the model.
Lists the properties that are not used.
Deletes the unused properties.
Not supported.
Mass Property having zero mass
Checks for Mass elements with zero mass value.
Lists all Mass elements with zero mass value.
Not supported.
Opens the Property panel.
Free mass elements
Checks for Mass elements with no property.
Lists all Mass elements with no property.
Not supported.
Opens the Property Creation panel.
Empty components
Checks for components that do not contain elements.
Deletes the empty components.
Not supported.
Contact ghost elements have no base elements
Checks if the contact elements created for interface have a base element.
Lists all interface entities that have a contact element without its base element.
Not supported.
Opens the Interface panel, Add page.
Empty Group Surface
Checks if the surface in the group has elements.
Lists surface groups that are empty.
Not supported.
Opens the Interface panel.
Unused Sets
Checks if any sets are unused.
Lists the unused sets.
Deletes the empty sets.
Not supported.
Empty sets
Checks if the sets are empty.
Lists the empty sets.
Not supported.
Unused systems
checks if any systems in the model are not used.
Lists the unused systems.
Deletes the unused systems.
Not supported.
Unused contact surface
Checks if the contact surface defined in the model is unused.
Lists all unused contact surfaces.
Deletes unused contact surfaces.
Not supported.
Unused Beam Section
Checks if any beam sections are unused.
Lists all the unused beam sections.
Deletes the unused beam sections.
Not supported.
hmtoggle_plus1greyInfo
Name
Result
Number of Material
Checks for the number of material entities in the model.
Lists all of the materials.
Not supported.
Not supported.
Number of Properties
Checks for the number of property entities.
Lists all of the properties.
Not supported.
Not supported.
Number of Comps
Checks for the number of  component entities.
Lists all of the components.
Not supported.
Not supported.
Number of Groups
Checks for the number of group entities.
Lists all of the groups.
Not supported.
Not supported.
Number of Sets
Checks for the number of set entities in the model.
Lists all of the sets in the model.
Not supported.
Not supported.
Number of Steps
Checks for number of step entities in the model.
Lists all of the steps in the model.
Not supported.
Not supported.
