Engineering Solutions
PAM-CRASH Connector Types
Previous topic Next topic Expand/collapse all hidden text
PAM-CRASH 2G plink (connector position)
CFG pamcrash2g 1 plink (connector position)
*filter spot
*head
*body 0
mass 5 2
*post prop_plink.tcl
cfg_pamcrash2g_1_plink
Description: Creates a PLINK element. The PLINK is created at the connector location.
This realization also uses the prop_plink.tcl property script.
This script is called while creation of PLINK– custom config welds in the Spot panel inside PAM-CRASH user interface. This script does the following tasks:
Organizes the PLINK weld elements created during realization process into C_PLINK_PSCRIPT_<id1_id2> component with the PART_LINK card image associated to it. The id1 and id2 shown above refers to the ids of the link components with which the connector is connected to.
Creates the M_PLINK_PSCRIPT_<id1_id2> material collector, with the MAT_LINK card image associated with it. This material collector is referenced in the above created component containing the PLINK weld elements.
Updates the various attributes to the above created material/ property cards.
PAM-CRASH 2G plink (middle of the gap)
CFG pamcrash2g 2 plink (middle of the gap)
*filter spot
*head
*body 0
mass 5 1
cfg_pamcrash2g_2_plink
Description: Creates a PLINK element. The PLINK is created at the center location between the two components and is offset from the connector location.
PAM-CRASH 2G bolt (spider)
CFG pamcrash2g 54 bolt (spider)
*filter bolt
*style bolt 1
*head
*body 0
rigidlink 1 1
cfg_pamcrash2g_54_bolt
Description: Creates an RBODY element. The body element projects and connect to the nodes of the adjoining shell elements.
PAM-CRASH 2G link
CFG pamcrash2g 55 llink
*filter seam
*style parallel 1
*head
*body 0
rod 5 1
*post prop_llink.tcl
cfg_pamcrash2g_55_llink
Description: Creates LLINK elements. The LLINK elements are created along the line connector.
PAM-CRASH 2G adhesives(contact)
CFG pamcrash2g 56 adhesives (contact)
*filter area
*style adhesive 1
*head
*body 1
hex8 1 1
penta6 1 1
*post prop_pam_rad_adhesives.tcl
cfg_pamcrash2g_56_adhesives_contact
Description: This realization creates rows of HEXA and PENTA elements for the body. The HEXA and PENTA elements project and connect to the adjoining shell/solid elements by touching them.
The realization uses the prop_pam_rad_adhesives.tcl property script.
The script performs the following tasks:
1.Creates groups with the name ADHESIVES_CONTACTS_PID_=_#, which reference the independent/dependent link's master sets and the node's slave sets (# is the ID of the links).
2.Organizes the link entities (components, and so on) into a set with the name MASTER_PART_SET_PID_=_#_parts, which is referenced by the set MASTER_PART_SET_PID_=_#, which is referenced by the above link groups (# is the ID of the link entity).
3.Organizes the solid's nodes on links into a set with the name SLAVE_NODE_SET_PID_=_#_nodes, which is referenced by the set SLAVE_NODE_SET_PID_=_#, which in turn is referenced by the above link group (# is the ID of the link entity).
PAM-CRASH 2G hexa (adhesive-shell gap)
CFG pamcrash2g 57 hexa (adhesive - shell gap)
*filter seam
*style continuous 2
*head
*body 0
hex8 1 1
*post prop_pam_adhesives.tcl
cfg_pamcrash2g_57_hexa_adhesive_shell_gap
Description: Creates a row of hexa elements for the body. The hexa elements are projected so that they touch the elements of the connecting components.
This realization uses the prop_acm_adhesives.tcl property script.
1.Organizes the HEXA elements and nodes into a component with the name ADHESIVES_#_@ (# is the entity ID of the independent link and @ is the entity ID of the dependent link).
2.Creates groups with the names ADHESIVES_CONTACTS_PID_=_#, which reference the independent/dependent links' master sets and the nodes' slave sets (# is the ID of the links).
3.Organizes the link entities (components, and so on) into a set with the name MASTER_PART_SET_PID_=_#_parts, which is referenced by set MASTER_PART_SET_PID_=_#, which in turn is referenced by above link group (# is the ID of the link entity).
4.Organizes the solids' nodes on links into a set with the name SLAVE_NODE_SET_PID_=_#_nodes, which is referenced by the set SLAVE_NODE_SET_PID_=_#, which in turn is referenced by the above link group (# is the ID of the link entity).
Note:The names of the dependent links node sets are SLAVE NODE SET PID_=_#_nodes and SLAVE NODE SET PID_=_#.
PAM-CRASH 2G hexa (adhesive)
CFG pamcrash2g 58 hexa (adhesive)
*filter seam
*style continuous 3
*head
rbe3 1 0
rigid 1 0
*body 0
hex8 1 1
cfg_pamcrash2g_58_hexa_adhesive
Description: Creates a row of hexa elements for the body and numerous RBE2/RBE3 elements for the head. The head elements project and connect to the nodes of the adjoining elements. If there is a direct normal project then RBE2 element will be created, if there are only non-normal projections then RBE3 elements will be created. The hexa elements are projected so that they touch the elements of the connecting components.
PAM-CRASH 2G hexa (tapered T)
CFG pamcrash2g 105 hexa (tapered T)
*filter seam
*style continuous 6
*head
*body 0
hex8 1 1
hexa_tapered_t
Description: Intended to be used for t-cases. The size and exact position can be defined thickness dependent, or the exact dimension and position parameters can be given.
