Engineering Solutions
Parasolid Metadata Support
The Parasolid reader generates the following metadata:
COLOR_RGB
Entities
string
points
lines
surfs
solids
Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model.
Generated when @ColorsAsMetadata = on
DENSITY
Entities
double
solids
The value of the density of a solid.
Generated when @DensityAsMetadata = on
MODELUNIT
Entities
integer
comps
The model units specified in the CAD file.  Values include:
1 = inches
2 = millimeters
4 = feet
5 = miles
6 = meters
7 = kilometers
8 = mils
9 = microns
10 = centimeters
11 = microinches
12 = decimeters
13 = yards
This is always generated.
<name>
Entities
integer
double
string
points
lines
surfs
solids
comps
assems
The <name> field is the CATIA attribute name and the integer/double/string is the value of the CATIA attribute.
Generated when @AttributesAsMetadata = on
ORIGINAL_ID
Entities
string
points
lines
surfs
solids
The original CAD entity ID.
Generated when @OriginalIdAsMetadata = on
TAG
Entities
string
points
lines
surfs
solids
The tag (name) of the entity as read from the CAD model, if one exists.
Generated when @TagsAsMetadata = on
UNIQUE_ID
Entities
string
lines
solids
surfs
A combination of the body identifiers and the Parasolid entity ID.
Generated when @UniqueIdAsMetadata = on
See Also:
Parasolid Import Options
Parasolid Reader Support
CAD Import Options
